Previous in Forum: Oil Filteration of Transformer   Next in Forum: Float Voltage for Battery and its Charger
Communication Cable
11/03/2011 1:23 AM
- what is - ' no conductor smaller than 32 / 0.2 mm (1 mm2) shall be used for interconnecting cabling' - what does this 32 / 0.2 mm (1 mm2) represent? Here, we are talking about communication cable.
regards,
sks
Pathfinder Tags: cable communication cable
Re: communication cable.
11/03/2011 1:29 AM
The given numbers are inconsistent with each other.
American Wire Gauge AWG 32 ≈ 0.00795 inch diameter ≈ 0.202 mm diameter; with an area of ~0.0320 mm2. The 1 mm2 is the inconsistent number.
See this for further info.
11/03/2011 1:54 AM
i want to quote the following excerpt from the manual !!
"No conductor smaller than 32/0.2 mm (1 mm2), or having less than three strands shall be used for interconnecting cabling except in the case of telephone extensions."
could not justify (1 mm2)....??
Regards,
sks
11/03/2011 2:33 AM
I don't know where they got 1 mm2, and I'm pretty sure they don't know, either. Literature sometimes contains mistakes, so it is good to know some basic calculations for the purpose of double-checking.
11/03/2011 2:52 AM
thanx.
sks
Good Answers: 181
11/03/2011 1:24 PM
I'm going to be blunt once again, sauravbabu, you are totally incompetent!
Pleases find a new occupation!
Re: Communication Cable
11/03/2011 5:24 PM
Quote "I'm going to be blunt once again, sauravbabu, you are totally incompetent!"
Mr Tony
That is a little vague. Don't you think you should be more clear in your comments so that the OP can understand what you mean?
Register to Reply 6 comments
sauravbabu (2); TonyS (1); Tornado (2); wareagle (1)
