Previous in Forum: Rotation of Turbine   Next in Forum: GateValve Handwheel Orientation
Vert Vessel-Support Legs
11/05/2011 2:27 AM
Dear All,
I have a vessel of ID 2200 mm and height 6000mm (TL to TL).
It has torispherical dish at both ends.
Internal pressure:1.62 bar(g)
The support legs are placed on the bottom dish at a PCD of 1680mm.
Thus the support legs are welded to rf pads on bottom dish. (no contact with shell).
Please help me regarding the thickness of bottom dish. how to verify it?
Should i use nozzles on bottom dish at that PCD and use WRC 107 to superimpose the loads on nozzle experienced by legs?
I have used compressive load on all 4 nozzles (P Load in WRC 107). is it too conservative? since there will be no opening.
Regards
ASD23789
The light of blindness of knowledge is yet to reach me, forget being clever.
Pathfinder Tags: Leg Support Legs
Re: Vert Vessel-Support Legs
11/05/2011 2:34 AM
Some key elements are missing:
How heavy is the liquid (if any) in this vessel?
How many legs?
Seismic zone? Wind loads?
11/05/2011 2:40 AM
1) Liquid Sp Gravity : 01
2) Leg Qty:04 MOC :SS304 Leg Size : 150 NB Sch 40
3) Wind speed: 140 Kmph
4) Seismic Zone : IS873 (India)
Hope this helps.
Regards
ASD23789
11/05/2011 7:18 AM
Dear asd23789
Greeting to you
First: about thickness of lower torispherical head
by using appendix 1 equation 3 & fig. (b) t = PLM/2SE-0.2P
WHERE p = internal design pressure = 0.162 MPa . and you must increase the static head due to height which equal TL to TL length of vessel + depth of upper head and lower head ( assume 2*800 = 1600 mm check on your case) + 30% for safety
so static head = dinesty of internal fluid (1000 kg/m3) * height ( 8.800 m) * acceleration (10 m/s2) = 0.088 Mpa
so the net internal design pressure = 0.162 + 0.088 = 0.25 MPa
M Factor depending on L/r (in case of torispherical) review fig (b). I will take it (1) but you must check it in your case according to L/r
E joint eff. ( take it 0.85 spot)
S MAXIMUM ALLOWABLE STRESS (assume head material SA-516 gr.70 ) = 138 MPa
FROM EQUATION 3 appendix 1 t (thickness) = 2.4 mm ( minimum required thickness) + C.A ( 3 MM) = 5.4 MM TAKE nominal thichness = 6 mm ( as minimum)
SECOND : you can use nozzle at the bottom but you must check using WRC107
third : if you mean that the nozzle will be no opening that there is no extension piping from this nozzle - like handhole or inspection hole - you do not need to check it with WRC 107 , you must only check by area compensating calculations in UG.37 , and you do not have to do the check in UG.45 if there is no extension piping from this nozzle.
if there is extension piping from the nozzle you must do all calculations .
enlightenment is blessing and self-denial is a good recipe
11/21/2011 12:38 AM
Dear blackpanic73 Sir,
Thanks for you r reply.
But you mentioned 30% for safety. will you please explain it?
Register to Reply 4 comments
asd23789 (2); blackpanic73 (1); Tornado (1)
