Previous in Forum: Power Factor Measurement   Next in Forum: Elctrical Grounding/Earthing
10 comments
Electrical Insulation Resistance Test
11/06/2011 12:37 AM
Dear sir,
I was doing the Insulation Resistance test (1000V Megger)for Main LT switch board, but Insulation value is coming around 100Mohms.But Consultant rejected the test due to low Insulation .Kindly let us know what is the Min.Insulation resistance value as per IS/IEC .
Re: Electrical Insulation Resistance test
11/06/2011 12:47 AM
Get your own copy of the specifications that you claim to be testing to.
Your ignorance of electronics is inexcusable for someone who, apparently, is taking money from other people to fabricate and test electrical devices.
Please tell me I'm wrong.
11/06/2011 4:24 AM
what is the voltage of your LT board?
if it is 415 V then accepted value is 1.415 Mohm.
standard accepts kV+1 Mohm IR value for each voltage level.
11/07/2011 12:01 AM
According to VDE it should be 1000ohms/kV. What is the recommended test voltage?.
pnaban
Good Answers: 170
11/06/2011 8:42 AM
Change your consultant. As per Indian Electricity Rules. 1956, Rule No. 48 (i), the minimum insultaion resistance for 415V installtion, with a test voltage of 500V DC, is only one mega-ohm.
Re: Electrical Insulation Resistance Test
11/06/2011 10:41 PM
Dear Mr
As per IEC 1 Mega Ohms /1 KV is ok
11/07/2011 10:25 AM
100 MΩ IS MORE THEN ENOUGH.FOR 415 V LT POWER 1MΩ IS RECOMENDED VALUE BY IR RULES.YOUR CONSULTANT IS WRONG.
11/07/2011 12:39 PM
The specification is "The Specification". If their expectations are unrealistic, then refer them to "Somebody Else".
11/07/2011 10:44 PM
Good insulation resistance . Don't have to worry at all . ( Operating voltage divided by 1000 ) + 1 megohms is the thumbrule . Soo 100 mohms is very good .
11/08/2011 3:34 AM
if you are working in UAE, then most consultants prefer a perfectly insulated wire/ busbar i.e >999Mohm.
even though IEC & British Standards mention a insulation resistance of 1000ohm/volt (IEC) & >=1Mohm (BS) for a LV system using a test voltage of 500V or 1000V dc , the consultants still prefer the highest value shown in the megger which is >999Mohm.
using a megger-insulation-tester
11/13/2011 11:12 AM
Hi every1... I have a similar question.
What is the IR value that is expected in LT power cable(1100 V), when tested at site before laying the same. Is the value universal? Please give the separate values for XLPE and PVC cables, 500m and 1000m each.
Many thanks in advance....
Register to Reply 10 comments
Alwin Paul (1); electricalexpert65 (1); Gazu (1); harrybrown (1); lyn (1); muditmah (1); murugavelt (1); pnaban (1); SCSharma17 (1); Voltamps (1)
