Previous in Forum: Circuit Breaker Rating   Next in Forum: Electrical Insulation Resistance Test
11 comments
Power Factor Measurement
11/05/2011 10:06 PM
we can measure the power factor correctly by using PLL but i want to know what can be used along with PLL to measure if power factor is lagging or leading.
Re: Power Factor Measurement
11/05/2011 11:49 PM
Have you ever seen a power factor meter?
11/06/2011 12:21 AM
Kill A Watt has one.
  • Displays 8 critical units of measure:
    • Voltage (Volt)
    • Frequency (Hz)
    • Current (Amp)
    • Volt Amps (VA)
    • Watts (Watt)
    • Power Factor (PF)
    • Kilowatt Hours (KWH)
    • Elapsed Time
This is not an endorsement, but I bought one and, for the price, you should have one too.
11/06/2011 12:25 AM
Yeah, but I was asking if the OP had seen any such device.
11/06/2011 12:32 AM
Oh.
11/05/2011 11:49 PM
11/06/2011 4:26 AM
please tell what is PLL first and how does it exactly calculate pf in your case?
for pf measurement
only voltage and current input is needed in a meter.
Many types of digital pf meters are now available. AE make some of them.
11/07/2011 12:22 PM
PLL is phase lock loop.It is an analog device and can be easily used for power factor measurement, frequency measurement.
In a pf factor meter, only current and voltage is needed but i'm trying to introduce the analog device to have a more accurate value of pf.
Good Answers: 170
11/06/2011 8:44 AM
What is PLL? Phase Locked Loop? And, today in the market you can get a wide variety of very precise Analogue and/or Digital Power Factor Meters. You can use one of them.
11/07/2011 12:33 PM
sir please tell me the names of few analog devices that can measure the power factor as well as if power factor is lagging or leading.
Good Answers: 170
11/07/2011 8:44 PM
You can select from the analogue power factor meter ranges of MECO, IMP, RISHAB, AE, etc.
11/14/2011 11:48 AM
okay...thanks!
Register to Reply 11 comments
electricalexpert65 (2); lyn (2); muditmah (1); Tornado (2); Vibhuti Garg (3); wareagle (1)
