Previous in Forum: Simple physics may not be enough   Next in Forum: Question about posting replys?
Calculation of the Air Density
04/26/2007 7:08 AM
I want to know about the general formula for the calculation of the density of air at various temperatures and pressures,say if the temperatures is 300 centigrade and pressure is 0.5 bar, what would be the density in Kg/cubic metre.
please also explain that when "bar" is a unit of pressure(which is the force acting per unit area),why the area is not mentioned with this unit of pressure?
Same is the question about "pascal" unit.
Thanks in advance for the considerations and responces of the members.
Re: calculation of the air desity
04/26/2007 7:27 AM
The Bar and the Pascal are units of pressure, which has the dimensions of force/area. This may help: http://www.simetric.co.uk/.
The properties of dry air may be found in published volumes of steam tables, like Mayhew & Rogers.
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
Re: Calculation of the Air Density
04/26/2007 11:28 PM
For the density of air, you can calculate density at various temps and pressures by using the ideal gas law (PV = nRT). There is lots of info on the net about this so I will not go into further detail.
As for the units, Pascal and bar are pressure units defined as:
Pascal [Pa] = 1N/m2
Bar = 100,000Pa
If you are interested in how why these units are named, try a web search, maybe Wikipedia.
fm!
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
04/27/2007 12:24 AM
1 bar = 1 atmosphere.
04/27/2007 3:09 AM
not really correct:
1atmosphere=1.01325bar
see http://en.wikipedia.org/wiki/Atmosphere_%28unit%29
Good Answers: 137
04/27/2007 4:11 AM
Density of dry air at 0°C and 1 bar absolute is 1.27 kg/m3 near enough for most purposes. At other temp T°C and pressure P bar density = 1.27*P*273/(273 + T) kg/m3. Note pressures are absolute.
Cheers....Codey
Good Answers: 18
04/27/2007 7:44 AM
Yep, and so are the temperatures . . .
Good Answers: 137
04/27/2007 8:18 AM
Hello Bill - not in my formula. There's 273 in the denominator so T is in °C. I suppose to be consistent with P being absolute, should say 1.27*P*273/T kg/m3, T in °K, but it works either way.
Codey
Register to Reply 7 comments
Anonymous Poster (2); Bill (1); Codemaster (2); fattmaxx (1); PWSlack (1)
