Previous in Forum: Question of Flyback Transformer in DC Step-up Converter Design   Next in Forum: Industrial/Manufacturing Engineer
11 comments
Neutral Earthing at Load End
11/08/2011 8:02 AM
can we earth neutral of cable seperately at load end, is there any effect on Asymmetrical current component and fault current?
Good Answers: 170
Re: Neutral Earthing at Load End
11/08/2011 8:47 AM
Neutral MUST always be earthed only and ONLY at the source, nowhere else.
11/09/2011 12:47 AM
is there any standard formula for deciding earth conductor size.
Good Answers: 170
11/09/2011 1:37 AM
S = I Root 't' / K
S = Earthing Conductor Cross Section in sq.mm
I = Fault Current in Amperes
t = Duration of fault, in seconds
K = Constant, depending upon the material of conductor, fault duration, etc. (Refer to IS 3043 for the values of these constants)
11/09/2011 11:57 AM
British Standard 7671.
12/05/2011 2:03 AM
Your answer is wrong, this is mentioned in articles below. With respect beware replying if you do not have the correct answer it may confuse the poster.
India - Member - New Member
Good Answers: 164
12/05/2011 2:33 AM
dbman
Which articles? Nothing is there in your post.
We are all very curious to learn from you especially since you seem very sure of yourself. i hope you will ensure that your future posts will be complete.
Good Answers: 44
11/08/2011 10:06 AM
Boy! Are you in luck!
This was just covered recently...right here on CR4! How much more on-topic and essential can you get than the forum of CR4?
http://cr4.globalspec.com/thread/73442/Grounding-Topics
Thank you, God, for CR4. (p.s., could you please include some instructions on the search function?) If it's not asking too much...
Good Answers: 164
11/08/2011 10:57 AM
Actually, thanks to Wareagle !!!
Good Answers: 44
11/09/2011 10:09 AM
That, too...
11/08/2011 11:54 AM
Although it can be, there is no earthly reason [] why it should be.
Please refer to British Standard 7671.
There is a page in Wikipedia on earthing systems that shows the methods of earthing and the reasoning behind them.
11/09/2011 12:48 PM
Failing that, consult a qualified electrician.
Register to Reply 11 comments
cuba_pete (2); dbman (1); electricalexpert65 (2); kvsridhar (2); PWSlack (3); santosh zingurde (1)
