Previous in Forum: '02 Lexus IS 300 Mass Air Flow (MAF) Sensor   Next in Forum: Mercedes ML350 Code Failure P0715
CR4 IC Engine
11/08/2011 1:01 PM
What is CR4 IC Engine? How it is different from conventional IC Engine
Re: CR4 IC Engine
11/08/2011 1:23 PM
In a CR4 Internal Combustion Engine
  • Internal temps tend to run high
  • some tend to have to much hot air
  • occasionally a fire breaks out but can be self extinguished most of the time
  • the "brains" or computers have top notch processors
  • built in many countries
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Re: CR4 IC Engine
11/08/2011 1:43 PM
Re: CR4 IC Engine
11/08/2011 9:04 PM
It also tends to stall quickly or at best sputter a lot and always backfires when trying to be run on poorly researched or unrealistic AE fuels.
Re: CR4 IC Engine
11/08/2011 9:05 PM
Here's an engine for you. Here's what the developer said to me today:#16
New Split Cycle Engine Concept: The Doyle Rotary Engine - YouTube
Register to Reply 4 comments
lyn (1); Mikerho (1); tcmtech (1); thall (1)
