Previous in Forum: SONY DIgital Camera Language Setting   Next in Forum: Inter Card Connection Diagram
47 comments
Laser Internet
11/11/2011 9:49 AM
There is a mountain between where I live and the nearest town with internet access. I would like to bounce a laser beam off a nearby snowcapped mountain to transmitt my internet signal. I would need two lasers and two photoresitors. A laser to transmit and a photoresistor to recieve on both ends.
Would a 200mw green laser be enough to slice through fog? There are about 10 miles between me and the snowy mountain.
Any possible designs or any other that I could get good internet would be welcome. Satellite internet is too expensive and 3G is too slow in my area.
Re: Laser Internet
11/11/2011 11:20 AM
You, of course, will be mounting a mirror on the mountain, right?
And some provision to keep the mirror clean and dry?
Other wise, too much difussion for any coherent signal.
I can't speak to the penetration characteristics of lasers through clouds, nor the FAA rules of lasers and aircraft flying through same.
Re: Laser Internet
11/11/2011 11:21 AM
My experience is as an astronomer, and I don't know of any visible wavelengths that will slice through fog or clouds. In fact, for public demonstrations green lasers are commonly used to point out particular stars because the green wavelength is back-scattered very well, making the laser beam visible for use as a pointer -- more so in the summer when the air is more humid. On the other hand, radio astronomers don't have that problem; they can work even with overcast skies. I think your best bet would be some radio wavelength.
Another option might be infrared laser diodes. Ones in the 1600 nanometer range are available, and the atmosphere is fairly transparent in this wavelength region. I didn't find any info on the transparency of clouds in this wavelength range, though.
Re: Laser Internet
11/11/2011 12:04 PM
Follow up to my response above.
I was thinking you might bounce the IR signal off the mountaintop snow and read the scattered signal using small telescopes in front of your IR sensors -- so you would not need to place a mirror near the top of the mountain. Unfortunately, the report in the link below shows that the reflectivity of snow is poor in the near infrared, so a ~ 1600 nm laser diode would not work this way. You would need some kind of reflective surface. Maybe not a 'mirror' per se, but something that is reflective in the near infrared. I seem to recall reading once that ordinary cardboard is reflective in the near infrared.
http://www.civil.utah.edu/~cv5450/Remote/AVIRIS/optics.html
Good Answers: 62
Re: Laser Internet
11/11/2011 12:34 PM
To tackle as you describe you'd need to drop a couple frequency bands down to RF but while that would give you a detectable signal, actually encoding same and getting anything but garble would be a challenge and very unlikely at data rates to support internet access.
Two possibilities to your solution:
One - mount a microwave receiver on the far side of the obscuring mountain, cabled to a transmitter on your side - solar panel power it. Surprisingly affordable, but will offer speeds that allow commercializing it to your neighbors to help defray.
Two - is sort of related in that it depends on sharing costs with neighbors, set up your own satellite down-link. Hughs has a functional satellite service competitive in cost for individuals users, and offers a commercial service you could sell to your neighbors.
Re: Laser Internet
11/11/2011 12:54 PM
Who is Hughs?? And where can I find microwave tower companies?? They seem elusive. Great idea, though. Also, could I just put a wifi repeater on the mountain if it is powerfull enough??
Good Answers: 62
Re: Laser Internet
11/11/2011 1:10 PM
Hughs Most of their business now is RV and truck internet over a 12" dish.
Used to be one of many satellite manufacturers.
Towers and relays are sold separate unless you have a large checkbook I'd use trees.
They are hard to track down, but a lot of companies sprang up servicing exactly your problem with 12" microwave tech. by mounting the antenna on your chimney and pointing a ground based transmitter at you.
Mostly seems to have been superseded by cheap (relative term) satellite access.
Re: Laser Internet
11/11/2011 1:22 PM
Wow. Good Idea. Also, my mountain is very rocky so I could just bolt the dish to the rocks.
Re: Laser Internet
11/11/2011 1:24 PM
What about a high power wifi connection. I think I was wrong when I said that it was 10 miles to the mountain to reflect of of. It is really no more than 4.
Good Answers: 62
Re: Laser Internet
11/11/2011 1:28 PM
http://www.mybluedish.com/
They don't do point to point, they do cheapish satellite - but to be a real hall-monitor stickler - it is actually microwave
Re: Laser Internet
11/11/2011 1:39 PM
The problem with all of the satellite internet companies that hve been mentioned so far is that they all appear to only work in the USA. A country in which I do not live.
Re: Laser Internet
11/11/2011 1:45 PM
Microwave really does sound good. All of the the satellite companies that you mentioned seem to only work in the USA: I don´t live there.
Sorry if I already said that. I thought I did but then I couldn´t find it.
Good Answers: 62
Re: Laser Internet
11/11/2011 2:40 PM
OTAY! Perspective fail on my part - where is home?
Re: Laser Internet
11/11/2011 3:31 PM
Chile, South America.
Re: Laser Internet
11/11/2011 1:11 PM
That works just fine provide you have large enough high gain directional antennas at the four points.
One at your place two on the mountain as the repeater station and one at the city site.
I personally use a high gain directional antennae system to get my high speed wireless from my brothers place about a half a mile way with an old windmill tower at the 90 degree repeater to get around a hill thats between us.
Being that the average WiFi router can work in different modes you would only need one on the mountain that can be set up for repeater duty to run the two directional antennae. Power wise you would need nothing more than a good solar panel and a good 12 volt battery to carry it being most WiFi routers use a 12 volt DC adapter for power anyway.
The most trouble you will have is tweaking your high gain directional antennae sets to hit each other which may take a few friends with cell phones and few road trips but its entirely doable with all off the shelf components!
Good Answers: 62
Re: Laser Internet
11/11/2011 1:23 PM
Stupid system OTd you for the best answer so far
but getting to it - NOW is when you get out the laser beams - for aiming
Re: Laser Internet
11/11/2011 1:36 PM
Exactly!!
Re: Laser Internet
11/11/2011 1:35 PM
What router did you use? was it very expensive?.
Re: Laser Internet
11/11/2011 3:32 PM
We are using standard issue off the shelf Wireless Access Point units from Linksys and Netgear. One WAP54G at each end with a simple software update to boost the output to its full capacity and another one programmed to work in repeater mode in the middle.
As far as directional antenna go you can get some high gain highly directional ones on eBay for reasonable prices.
One of our dishes can do a 36 M/S connection to a common laptop internal wireless card from over half a mile!
Ideally I would recommend buying an external WiFi connection devices that can connect to your USB port and antenna so that you can have an actual signal strength reading as you are aiming them.
A few degrees off on just one can mean the difference between a 24+ M/S link between dishes in heavy fog and a near zero link in anything but clear sky.
Re: Laser Internet
11/11/2011 3:49 PM
Thanks. Where do you get the firmware updates? Does it take anything special to set the middle one to be a repeater?
Re: Laser Internet
11/11/2011 4:38 PM
As far as I know its all available online for free and some of it comes directly from the manufactures sites.
Just find a high school kid that knows about basic wireless internet networking and you are set to go!
Good Answers: 120
Re: Laser Internet
11/11/2011 7:37 PM
You can use a passive directed re-radiation method.
All you need is a friend with a high gain wi-fi yagi to aim at the peak, which has two more of these yagis, one to receive and one to transmit and you on the ground on the other side of the mountain.
make a yagi
use these or similar yagis. If you have power on top of the mountain, you can add a gain block, just make sure it is bidirectional
One Yagi - google has more or make one from Google
Per Ardua Ad Astra
Good Answers: 102
Re: Laser Internet
11/11/2011 9:28 PM
Two words here: Link Budget.
If you don't know what this is then your chances of success are slim to none.
It is not impossible to implement a personal repeater system over these distances but the total cost and the logistics involved are not suited to individuals.
The low power laser, crude detection and imperfect reflector proposition tabled by the OP won't work.
Satellite internet connection is available on every continent.
Specifically for Chile see http://www.wafa.ae/en/vsat/products/hx/SouthAmerica/satellite-internet-in-Chile.aspx
If you have the resources you may even consider a micro(co-op) ISP, using this satellite backhaul, and share it with your community.
Good Answers: 120
Re: Laser Internet
11/11/2011 9:37 PM
Satellite internet starts at $150/month, with phone line command link. Bidirectional satellite costs even more.
With home made yagis and a solar powered gain block you can make a good link for $100 or so. purchased yagis will give better gain. As a test point a home made Wifi yagi at the top of the hill and then take a laptop with a wifi card you can attache to another home made yagi up there and see if it works. Then go from there.
Per Ardua Ad Astra
Re: Laser Internet
11/24/2011 8:10 PM
Exactly!!! And that is only for 300 kilo BITS (That is only 37.5 kilobytes) per second!! BURST!! For 150 dollars/month! Imagine how much speed you could get for the same price using the internet in town.
Good Answers: 102
Re: Laser Internet
11/11/2011 9:51 PM
The total all inclusive cost is a lot, lot more than $100. Reality 101.
Re: Laser Internet
11/24/2011 2:59 PM
Even if I buy the antennas new it will cost me less than $500. I already have the stuff on hand to build a solar power supply so the cost of that is not an issue. Even if my internet in town cost me $50 per month, I would save $1000 in 10 months assuming that satelite internet of comparable speed costs me $150/month! As I have shown, $1000 is plenty of money to do the job!
Re: Laser Internet
11/11/2011 10:24 PM
You'd better hope that no one accidentally looks at your laser beam and fries their eyes.
Good Answers: 59
Re: Laser Internet
11/11/2011 11:05 PM
You cannot make a go of the laser idea. Technically too complex to start with.
Internet connection implies two way communication. The upload (from you) may be done over regular phone line, and be very slow. But download (to you) need real speed. All that means really, that you need a real repeater on the mountain, and that, with building and power source is really, really expensive.
IF, and that is a big IF, the distances are small, only the geography is unlucky, a 10 meter long cable can serve as a sort of mirror for a Wifi link.
On the other hand, I would much rather explore the putting of DSL modems on the landline phones. They are always accessible, proven technology. Do not affect normal phone operation. The normal phone's copper pair carries the signal, at higher frequencies, all the time. One time expenditure.
Re: Laser Internet
11/24/2011 3:02 PM
No phone line either! We only have cell phone and that thanks to a booster.
Good Answers: 102
Re: Laser Internet
11/11/2011 11:18 PM
There is no Internet access apart from 3G at Campodogs' locale. DSL then is not an option. Tell us Campodog, how many others are there where you live (or work)? How many of them do you reckon would enjoy an Internet connection?
Re: Laser Internet
11/24/2011 3:09 PM
Lots of them would enjoy an internet connection! I would have to point another yagi antenna in their direction. They are to far away to bury a cable. It still is a good idea, though. Also, unless I had a bigger transmitter and a antenna that was less directional, I could only send internet to one of them at a time.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Re: Laser--better answer WIFI
11/11/2011 11:55 PM
You can do a wifi repeater tower on the mountain, if you can access a spot on the mountain where you can see your home AND a location in the city where you want to get your signal from.
I set up a local wifi internet service in my area since we are very rural so the big service providers don't want to bother with us because there aren't enough people living here to make it pay.
One of our repeater links is 22 miles with 350mW amplifiers and suitable antennas, on the license-free 5.8 GHz band. Its been a rock-solid link.
Our repeater towers consists of two reject 35' power poles for each repeater site--one for the radios and one for solar panels. We bury the battery box in the ground to avoid damage from frost and vandals.
The Wifi gear is all MikroTik...Google them--they make good, reliable gear and it's inexpensive--and available all over the world. The complete wifi gear on the repeater will cost you about $200. Of course, you will also need equipment at the opposite end of of each link which will cost you about $150 per side. The solar panels, solar charger and batteries will cost a couple of thousand $, depending on what you can expect for sunshine in the dead of winter on the mountain. The balance, for getting the poles, installing them, and making up a battery box, solar panel mounting frames, and electrical box for the solar charger is another $grand or so.
I've heard of bouncing radio signals off of mountain faces but can't give you any specifics. There is some info on Google. You would be using highly directional antennas, fairly low frequencies and lots of power because your mirror is imperfect. Probably not easily implemented unless you are an EE or a Ham radio type and willing to spend time experimenting.
Jon.
11/24/2011 7:55 PM
Yeah! Like how ham geeks bounce their radio signals off the moon.
Re: Laser Internet
11/13/2011 10:23 AM
connect your internet thru satellite connection..
guds777
Re: Laser Internet
11/13/2011 10:31 AM
this company http://www.mybluedish.com/ $49.95 per month.
guds777
Good Answers: 120
Re: Laser Internet
11/13/2011 6:47 PM
That
this company
sounds like it is a good deal.
I see they have caps and are slower than DSL, but still a lot better than dialup
I signed up for into and got this.
""Dear Bill,
Thank you for your interest in our satellite Internet services. Currently in the area we do have service available. Call us at 877-316-1892 now to get:
*Fast Speeds- Download speeds up to 2.0 Mbps
*Affordable plans- Package pricing starting at only $49.99/mo
*Reliability- 24/7 Always-on, wireless capable service with no phone line required
*Security- Our state-of-the-art, encrypted signal provides 24/7 protection for all your personal data and programs
Please give us a call at 877-316-1892 or reply to this email and we will be happy to go over all the details and answer any questions you may have about our services. We look forward to providing you with years of outstanding high-speed Internet!
Thank you for trusting MyBlueDish,
Jacob Minett
MyBlueDish President
877-316-1892
P.S. We can also bundle Internet/TV for only $79/mo. Check out or packages here: www.mybluedish.com/directv""
Per Ardua Ad Astra
Good Answers: 44
Re: Laser Internet
11/15/2011 3:12 PM
The OP is in Chile...
From Wild Blue:
"If you are in the 48 continental United States and have a clear view of the southern sky, you can receive WildBlue satellite broadband."
Re: Laser Internet
11/13/2011 6:26 PM
Perhaps a Maser(microwave) might work better in your environment .... but it will still need a purpose designed reflector.
Good Answers: 179
Re: Laser Internet
11/14/2011 10:03 AM
Laser or microwave don't do squat IF someone else owns that mountain and the OP has no LEGAL rights or permission to set up equipment there.
All the technical solutions in the world won't help if the legal beagle issues aren't solved first.....I know where I stand on this one since I've been involved in cell tower and microwave tower installations (structural and site design) for the past 15 years or so + sat on a NYS County Planning Board, as well as a Village Planning Board, where I've had to deal with siting applications for both.
Y'all missed the boat on this one guys! LOL
GO SATELLITE DISH IF AFFORDABLE!!!!!! [I have the Dish Network for cable TV but am considering Hughes Net for satellite ISP]/
Good Answers: 102
Re: Laser Internet
11/15/2011 6:58 AM
We didn't all miss the boat.
That is part of the total cost and logistics.
Permits, leases, licences, bribes, beers, food and women.
None of it is free
...and you're not even close to start building it yet.
Good Answers: 179
Re: Laser Internet
11/15/2011 8:03 AM
Well, it looks like I missed the boat on this one, or at least the gangplank...... Permits, leases, licences, bribes, beers, food and women.
Where was I when this was coming down???? LOL
Pssstttt!!! Don't tell Mrs. Moosie about the women part, or else she'll take away my Moosehead beer and make me sleep on my belly for months......
Re: Laser Internet
11/15/2011 11:33 AM
Here's the perfect beverage for you, from Big Sky Brewery in Missoula, Montana.
(No personal connection, but this is an endorsement--good stuff!)
Good Answers: 179
Re: Laser Internet
11/15/2011 11:57 AM
Hey thanks Tornado! This beer looks REAL PROMISING!!!!! LOL
I'll try to find it at our local beer distributor. Hopefully they will carry that brand, or at least they can order it for me! YUMMMMYYYYYYY!!!!!
Re: Laser Internet
11/15/2011 12:16 PM
It's available here in Ketchikan, and pretty widely in the west, I think. If not normally on sale in your area, you may be able to special order it.
I personally got Green Chartreuse introduced to Ketchikan by doing a custom order. It must have caught on, because pretty soon a competing liquor store was advertising it.
Chartreuse is an herbal liqueur made by French monks. The green version (100 proof) is superior to the yellow version; both are superior to Jagermeister, which I call "brown chartreuse." H.H. Munro ("Saki") once remarked that the religious system that invented Chartreuse could never really die. (But that would be an OT discussion.)
Good Answers: 59
Re: Laser Internet
11/15/2011 12:43 PM
Ahh, I will check it right away. Iagermeister is ok, but I am looking for a digestive bitter without the sweet in it. Any lead would be appreciated by me and my stomach.
best regards
Re: Laser Internet
11/17/2011 8:51 PM
This company looks pretty cool, you buy the receiver for $475, and buy as much time as you want or need...With time management this could be quite reasonable...Yes good for Chile..
http://www.tempestcom.com/services/satrbgan_plans.aspx
Re: Tempestcom is bad idea
11/24/2011 8:15 PM
I'm afraid $45,000 per year is too much to pay.
Register to Reply 47 comments
aurizon (3); campo dog (15); CaptMoosie (3); cuba_pete (1); edignan (5); guds777 (2); leveles (2); lyn (1); sawmilleng (1); SolarEagle (1); tcmtech (3); Tornado (3); Usbport (2); Wal (4); WAWAUS (1)
