Previous in Forum: Variable Speed Drive on Motor   Next in Forum: Current Carrying Capacity of Copper Cable
I Need a Wiring Diagram Baldor 1.5 hp Motor
11/11/2011 9:47 PM
AC 115-230 single phaze. need diagram to reverse motor. TEFC Frame # 184Z 1.5hp 1725 rpm.
Catalog # not listed but 184 frame # matches Catalog # L3603
Thanks in advance.
Jim
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: I need a wiring diagram baldor 1.5 hp motor
11/11/2011 10:09 PM
www.baldor.com
11/12/2011 12:08 AM
Try taking off the junction box cover on the motor. Often they have the wiring diagram printed on the back side. It may be as simple as exchanging wires 5 and 8 (or something like that).
Re: I Need a Wiring Diagram Baldor 1.5 hp Motor
11/12/2011 11:22 AM
This is a typical wiring schematic...
Voltage
Rotation
L1
L2
Join
High
CCW
1
4,5
2&3&8
CW
1
4,8
2&3&5
Low
CCW
1,3,8
2,4,5
CW
1,3,5
2,4,8
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
11/20/2011 5:56 PM
Hi Jim, single phase motors only come in one direction only, during manufacturing. (ccw or cw) You cannot change direction with the use of wiring. You can change direction by pulling the rotor and installing in opposite or trade it in for a new motor.
Cheers
Could be worse, it could be me. :)
11/20/2011 6:10 PM
Not necessarily true; see the 3 previous posts.
Good Answers: 130
11/20/2011 6:18 PM
Total BS - have another OT
11/23/2011 2:45 PM
I took a new Baldor 1hp out of the box removed the cover to reverse it and the winding lead had not been brought out were one could get to it (just my luck) but Tornado and Solar Eagle are right as usual...
It's not Rocket Science
Register to Reply 7 comments
34point5 (1); lyn (1); mayt2u (1); Rockyscience (1); SolarEagle (1); Tornado (2)
