Previous in Forum: CE marking for US made 3PH motor still good in UK w/different voltage specs?   Next in Forum: Nyloc Nut vs Plain Nut
8 comments
Calculation of Fabricated Bend made from PVC pipe
04/26/2007 3:17 PM
what will be Total Length of Fabricated bend made from PVC pipe.
given, pipe size = 160mm
redius = 3.0 m
angle = 90 deg.
socket = 120mm {length of one socket}
please provide calculation of result with standard formula
Re: Calculation of Fabricated Bend made from PVC pipe
04/26/2007 5:09 PM
What is the length of the pipe?
Pipe size = Diameter?
Radius is that the inside radius or the outside?
Angle is ok, I understand
what is the socket? Is that a preformed 90 deg bend? I thought this was fabrication, to me that means it's one piece and you want to bend it.
With more information I could draw it out for you and give you a sketch.
04/26/2007 6:36 PM
to find what is cut Length of the bend?
Given (as below)
pipe size = diameter= 160 mm
radius = outside =3m=3000mm
angle = 90 deg.
socket mean a bell is formed for jointing with pipelines=120mm
kindly consider all options such as additing straight portion
which will help to have 90deg.angle
regards n thanks
04/27/2007 10:41 AM
There you go.... 4586.71mm
04/27/2007 3:50 AM
It is rare to encounter a fabricated bend in PVC pipe.
04/27/2007 5:14 AM
Total length of pipe required to fabricate the 90o bend
= Socket at inlet+ (2*3.14*R)(A/360o) + Socket at outlet,
where R = Bend Radius & A = Bend Angle
= (120/1000) m + (2*3.14*3)(90o/360o) m + (120/1000) m
= 0.12 m + 4.71 m + 0.12 m
= 4.95 m
That length is the min. required without adding straight lengths (other than sockets).
04/27/2007 1:04 PM
R = Bend Radius: Outer Radius or Nominal Radius?
If Nominal Radius, R should be: 3000 – 160/2 = 2920 mm.
Well, it should be just a small difference...
04/27/2007 4:14 PM
Outer bend radius, R = 3000 mm
Mean bend radius, Rm is the radius at centerline = (3000-160/2)mm = 2920 mm Inner bend radius, Ri = (3000-160) mm = 2840 mm
I prefer to use R = Outer Bend Radius, 3000 mm (measured at outside radius of bend) in calculating the length of pipe required to fabricate that bend. That radius is more accurate which denotes to the max. length of pipe required.
If you use the radius measured at bend centerline Rm= 2920 mm in calculation, the pipe length is only measured at bend centerline, and you have to add two another segments.
01/31/2011 12:41 PM
Dear Mr. Halim,
We the CR4 Forum Members want to know whether you are safe.
Thanks,
DHAYANANDHAN.S.,
INDIA
Register to Reply 8 comments
Abdel Halim Galala (2); dhayanandhan (1); Labyguy (2); orange_431 (1); PWSlack (1); yesyen (1)
