Previous in Forum: ESD Ball Valves Operation   Next in Forum: Duct Work Issue
Hydraulic Motors
11/14/2011 9:02 AM
what factors should be consider befor slecting hydraulic motor.
Good Answers: 15
Re: hydraulic motors
11/14/2011 9:10 AM
Why don't you list the factors that you think are important?
Then we can add any that you might have missed.
Thanks for your effort.
downhill slide to 112 (damn memor.)
Re: Hydraulic Motors
11/14/2011 10:19 AM
Why not contact a hydraulic motor supplier and ask them to educate you.
They may, at least, make a sale and get some compensation for their effort.
Why should we waste our time doing you job for you?
Good Answers: 137
11/15/2011 6:39 AM
Exactly. To an engineer, the obvious things are little more than common sense.
01/04/2023 8:00 AM
No.1 is whether or not the telephone is working.
Good Answers: 137
01/04/2023 9:55 AM
Any particular reason you're posting on a thread from 2011?
01/06/2023 6:37 AM
"Proper hydraulic motor selection starts with the expected performance required by the application, then works back to the prime mover—the pump. Then it is necessary to evaluate the cost of your motor options along with the degree of complexity you want for the overall system."
You need to first figure out the horsepower and torque needed to accomplish the desired function....
...this will tell you the force needed to move the weight at the desired speed...this will then tell you what type of pump will be needed, and then you must decide how it will be configured, and what the cost options are....
https://www.mobilehydraulictips.com/select-the-right-motor-for-your-hydraulic-applications/
Register to Reply 6 comments
Codemaster (2); ddk (1); lyn (1); PWSlack (1); SolarEagle (1)
