Previous in Forum: Current Density   Next in Forum: Fuse Rating Selection
9 comments
Scope of Work for Inspection Main Transformer
11/15/2011 2:32 AM
Dear All
we have main transformer with capacity 27 MVA. The transformer is used to deliver electricity with a capacity of 20 MVA. Due to high enough temperature transformer that is 79 degree C, especially in the afternoon with the exhaust temperature of 489 degrees C, then the load of generator could not be maximum. Maximum load is only 15 MW. Due to implementation of Combustion Inspection for the next month, then what is the scope of work that should we do to the temperature transformer can be derive, so that the load can be increased at least 2MW.?
Re: scope of work for inspection main transformer
11/15/2011 4:42 AM
What does the transformer manufacturer say on this topic?
11/16/2011 2:16 PM
the manufacture is alstom. the specification data that we can read is,
manufacture : alstom,
rating : 27 MVA
Primary volt : 11 kV
Secondary Volt : 154 kV
vektor group : Yd11
Frequency : 50 Hz
Xt : 11%
thanks
Good Answers: 181
Re: Scope of Work for Inspection Main Transformer
11/15/2011 9:32 AM
What's the generator exhaust temperature to do with the transformer?
11/15/2011 11:36 AM
You might consider a cooling upgrade...ie. increasing number of fans...
11/15/2011 2:25 PM
Quote "we have main transformer with capacity 27 MVA. The transformer is used to deliver electricity with a capacity of 20 MVA. Due to high enough temperature transformer that is 79 degree C, especially in the afternoon"
Are you saying that you are operating the transformer at 79C? What is the name plate rating? You normally find the transformer with 2 ratings. An example might be 20 mva 55C/65C. This transformer with fans is rated 20 mva at 55C and 22.5 mva at 65C. Do you have fans on the transformer? Are you in the summer season at your location?
11/16/2011 2:22 PM
after doing DGA test to the transformer, we get some data as,:
Hydrogen (H2) 400 ppm
water (H20) 104 ppm
Carbon dioxide (CO2) 17987 ppm
Carbon Monoxide (CO) 536 ppm
Ethylene (C2H4) 68 ppm
Ethane (C2H6) 195 ppm
methane (CH6) 137 ppm
acetylene (C2H2) <0.5 ppm
TDCG 1335 ppm
because of the data above, need your recommendation as soon as.
regards
11/16/2011 5:28 PM
Quote " because of the data above, need your recommendation as soon as."
Then why not answer the question?
Does it have a voltage regulator? capacity? Or is it on a network?
IF you can not find the rating, suggest you ask the mfg for assistance.
11/17/2011 11:41 AM
You've got too much moisture, should be below 35ppm, you have to dry it out...You're CO2 readings are off the chart, probably due to cellulose insulation degradation, due to moisture...otherwise looks to be in fair condition...from this limited data...
11/18/2011 1:19 AM
thank solar eagle.. you are right, the data is very limited. we cannot do anything before the transformer is off. Right now the condition of transformer is still running with high temperature about 70-78 C. Maximum Load is only 15 MW, from the capacity is 20 MW.
PWSlack (1); rita.triani (3); SolarEagle (2); TonyS (1); wareagle (2)
