Previous in Forum: turbine vibaritions   Next in Forum: Heat Shrink Sleeve for Copper Bus Bar
Space Heater Provision in LV Electrical Panel
11/15/2011 11:38 PM
Dear SIr,
Kindly let us know the location of the space heater & thermostat in an Main Power distibution electrical Panel.
Regards
Murali
Re: Space heater provision in LV Electrical panel
11/16/2011 12:22 AM
The heater should be located near the bottom, on whichever side has more space below any heat-sensitive components. The thermostat sensor should also be near the bottom, but at the opposite side from the heater. This configuration will induce a convection loop of warmer air rising from the heater, falling down on the other side, and then passing across the sensor.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
11/16/2011 12:55 AM
3 best possibilities.
1-> heater bottom, thermostat top
Reason: heater at the bottom to heat the cool air located at the bottom of the enclosure & thermostat at the top to monitor the temperature as by natural convection hot air will move vertically.
2-> heater bottom, thermostat bottom (opposite sides)
Reason:heater at the bottom to heat the cool air located at the bottom &thermostat at the bottom so that it is shielded from radiated heat & also it will monitor the lower end of the panel
3-> heater bottom, thermostat top (opposite sides)
Reason: Same as 1
also take care that there are no tripping devices (MCB, MCCB) nearby the heater. it may cause unnecessary tripping due to the external heat.
shamith gambhir, electrical engineer
Register to Reply 2 comments
