Previous in Forum: Space Heater Provision in LV Electrical Panel   Next in Forum: Relay Contact Protection
Heat Shrink Sleeve for Copper Bus Bar
11/16/2011 12:16 AM
how to arrive the heat shrink sleeve for copper bus bar?
Pathfinder Tags: sleeve
Re: sleeve
11/16/2011 12:26 AM
It can arrive by Planes, Trains, Automobiles, or even Ships.
Re: sleeve
11/16/2011 2:26 AM
The original inside circumference of the heat shrink sleeve must be larger than the perimeter of the bus bar; when divided by the shrinkage factor, the inside circumference of the sleeve must be less than the perimeter of the bus bar. Select accordingly.
Re: Heat Shrink Sleeve for Copper Bus Bar
11/17/2011 12:43 PM
Depending on the application and voltage, mastic tape may be a better option.
For example - 3M mastic tape suitable for high voltage busbars
03/05/2012 9:56 AM
What matters is the thermal conductivity as well as non halogen materials. Use Raychem heat shrink tape if busbar cannot be opened. Otherwise the heat shrink sleeves can be used. Please refer Raychem selection and installation guide for Raysulate materials available at TE connectivity website
Register to Reply 4 comments
amitbhatia (1); Anonymous Poster (1); jack of all trades (1); Tornado (1)
