Previous in Forum: Converting N/mm2 Into Kilograms   Next in Forum: Electrolisys
9 comments
Hydro test
11/19/2011 7:28 AM
For Pressure vessels and pipe lines, what is the criteria and requirement for holding time.
Re: Hydro test
11/19/2011 9:29 AM
Good Answers: 61
Re: Hydro test
11/19/2011 9:54 AM
Try "Google" and "Hydrotest Procedure"
Do it once and do it right
Re: Hydro test
11/20/2011 12:49 AM
for pipes 1 hr is enough.for pressure vessels , i think same 1hr duratiion which we done earlier.
Re: Hydro test
11/20/2011 1:58 AM
The criteria for the holding time is to have enough time to be sure that there are not significant leaks due to defective material. Depending on the volume of the system that you are testing, it might be enough 10s - used for single pipe test during manufacturing - or it might be required to have 24h or even 48h for long piplelines sections - where you cannot do a detailed visual inspection for leaks and the drop in pressure, even if you have a leak, can take very long time.
Therefore go to the code of your application where probably is mentioned the minimum holding time required.
Re: Hydro test
11/20/2011 3:43 AM
Dear
hydrotest pressure=1.25 max allowable woring pressure
hold time = min 10 mintues or due reqired visual inspection
this according to NBIC (National Board inspection code) ASMEVIII
S2.6.1 HYDROSTATIC PRESSURE
TESTING
When performing hydrostatic pressure testing
for verification of leak tightness or when
required by the Jurisdiction, the following shall be met:
a) Hydrostatic pressure test shall be between
the calculated maximum allowable working
pressure and 1.25 times the calculated
maximum allowable working pressure,
and held for a minimum of 10 minutes or
as required to perform a complete visual
Eng. khaled
Good Answers: 179
Re: Hydro test
11/20/2011 10:12 AM
For water potable mains, AWWA requires a minimum of 2 hours hydro test......it's leakage and pressure test combined. Typically, maximum test pressure is 1.5 x Working Pressure.
HTH!
Re: Hydro test
11/21/2011 2:04 AM
As per ASME B 31.3 minimum holding time is 1 hour for pipes and again it varies from client to client requirement
Re: Hydro test
11/21/2011 11:01 AM
Hello everybody:
In addition to the comments posted so far, read this thread of Eng-Tips Forum http://www.eng-tips.com/viewthread.cfm?qid=277324 "Time duration for a pressure test".
Re: Hydro test
11/23/2011 7:02 AM
Why not ask the Engineer/Surveyor for the company that is supplying burst indemnity insurance cover for the equipment?
Register to Reply 9 comments
Anonymous Poster (1); CaptMoosie (1); crstn (1); ELEMAN (1); lyn (1); PennPiper (1); PWSlack (1); suvarna_mendu (1); YOGITECH (1)
