Previous in Forum: World's 'lightest material' Unveiled   Next in Forum: Hydro test
49 comments
Converting N/mm2 Into Kilograms
11/19/2011 1:31 AM
Hi.
I am giving LPG into the furnace @ N/mm2. How N/mm2 can be converted to get kilograms.
Thanks
Re: Converting N/mm2 into kilograms
11/19/2011 1:42 AM
That pair of units is incompatible.
However, there are some pipe flow calculations that could correlate N/mm2 pressure drop with something like kg/h flow. Is that what you mean?
11/19/2011 2:01 AM
Sorry. Intended to convert NM3 into kilograms
Thanks
11/19/2011 2:27 AM
There should be a density table for equating your gas volume to mass at various pressure/temperature conditions.
11/19/2011 11:01 PM
Propane ~ 2kg/m3
Butane~ 2.6 Kg/m3
These are at NTP
You have to find out what LPG mix %you are Buying
11/19/2011 10:39 PM
THAT IS BETTER
Good Answers: 19
11/20/2011 5:32 AM
1 m3 = 1000 kg. Is is not?
Good Answers: 75
11/20/2011 5:35 AM
Only if it's water.
Good Answers: 19
11/20/2011 5:42 AM
Sorry
The density of LPG at 15C at pressure of 1 bar is 500.0 kg/m3 to 510 kg/m3.
I take average between to and hence, it is 505.0 kg/m3
Good Answers: 19
11/20/2011 5:50 AM
Density of (a) Commercial Propane at 15c is .51 kg/kg per litre and
(b) Commercial Butane .58 kg/l . So for (a) 510.0 kg/m3 and (b) 580.0 kg/m3.
Good Answers: 19
11/20/2011 5:51 AM
Sorry read above as (a) .51 kg/L and (b) .58 kg/L
11/20/2011 11:33 AM
All the values you have given are for liquid!
The OP is asking about gas.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
11/21/2011 4:17 AM
The OP is asking about LPG...Liquified Petroleum Gas
He needs to density value of the mixed phase fluid at his T & P.
Chaos always wins because it's better organised.
11/21/2011 9:47 AM
My furnace burns LPG, but the Liquid is converted to Gas (boils to Vapor) before it exits the tank. No liquid ever gets anywhere near the furnace. Where does this mixed phase fluid exist?
In the Original Post, he was asking about N/mm2, which is a pressure value, and kg, which of course is a mass value, so no conversion possible.
In Post #2, he says NM3 to kg. I suspect that this is referring to Normal m3 (what I would refer to as m3 @ STP (Standard Temperature and Pressure). It could also refer to the normal temperature and pressure at which the fuel is delivered to the furnace. I don't know if STP has the same values in all countries.
If the densities provided by other posters does not answer the question, then we need much more specific information from the OP.
Good Answers: 75
11/21/2011 11:20 AM
Despite the OP being so short...I read it as a question of mass of gas in a tank/bottle rather than furnace delivery one (and yes, I'd noted the units issue, but that had been dealt with by the time I arrived).
From the linked article, propane has a vapour pressure of 22 bar. It seemed likely to me that the fluid in the tank would be mixed phase - gas and liquid.
As you say, if it's merely a volumetric flow rate to mass flow rate conversion that is required, then the gaseous density values are all that are needed.
11/21/2011 12:06 PM
When so little information is given, and especially with incorrect units, it is open to lots of different interpretations!
After post #33, we now know it is a flow rate, and I will assume that the N is for Normal, so it would be a gas. If this is the case, then post #5 should have answered the question.
Good Answers: 75
11/22/2011 6:47 AM
You're assuming I'm reading them in numerical order. I default to "nested", so often find I'm reading low numbered posts later.
I wasn't disagreeing with any of the numbers given (didn't do the research), just responding to the comment about LPG being a gas...you're reading too much into my initial post!
I think we've flogged this particular equine to death now! See you somewhere else
11/21/2011 3:13 AM
Only if it's liquid.
Re: Converting N/mm2 Into Kilograms
11/20/2011 4:55 AM
Dear Mr.ANKUSH JAIN,
Unless the DENSITY and TEMPERATURE of the gas, and FLOW RATE in Cu. Metre is known, it is not possible to calculate the weight of the gas in to Kilograms
DHAYANANDHAN.S
11/20/2011 5:05 AM
N/mm2 is a pressure while kg is mass. This is like asking how many amps is a Volt/s. Wherever you got that question from, some data has gotten lost on the way. Unless you find out what has gone missing or give more background, no one will be able to answer your question correctly. Good luck.
Good Answers: 102
11/20/2011 5:43 AM
Please confirm your units Ankush.
I'm guessing you want to convert cubic metres of LPG at normal temperature and pressure (20C and 1 atm) into kilograms of LPG. Do you have some metering issues?
I believe that Mukulmahant was unfairly given an off topic rogering. If Ankush can confirm then M will get a GA from me. Right now he gets an EG (excellent guess) from me.
As noted by M, LPG can be propane or butane and they have different densities.
11/20/2011 6:29 AM
Actually I have a background guess: LPG, delivered as a liquid, has a vapor pressure higher than atmospheric pressure. This means, it will evaporate if pressure is not maintained in the storage vessel. Consequently, the system has tankside over pressure. The furnace may use a pressure drop at its inlet to regulate flow. In essence a pressure reduction valve at the inlet is set to a certain value. That minus the pressure inside the furnace (atmospheric or very close to it) would be the pressure drop the system is set up for and at which it has it's design flow rate. In order to know the flow rate, one would have to know the relationship between the pressure drop and the flow rate. There are several ways to find that out: 1. Ask the manufacturer, 2. Install a mass flow controller (MFC), 3. base it on theoretical calculation. So if this is the background of your question there are possibilities to relate the two units, that is: Flow rate in kg/h is a function of inlet pressure in N/mm2 Am I on the right track?
Good Answers: 102
11/20/2011 7:01 AM
Who knows? The OP hasn't responded.
11/20/2011 8:02 AM
Propane=2Kg/cu.mtr
Butane = 2.6Kg/cu mtr -- Both at NTP
Not 500 Kg /Cu mtr as Ducon repeats
But the Questioner is missing!
He better knows Flowrate into Burners.-Nm3/min or hour
Only then can he get his Kg/Hour Consumption by the Furnace.
Discussions should end here.
Good Answers: 19
11/20/2011 9:44 AM
Sorry those figures are from the Propane Gas Association Canada
www.propangegas.ca
i never comment on anything not authentic.
Log on: www.propanegas.ca/FileArea/PGAC/Propane%20properties.pdf
or type"propane properties" on google and download Pdf.
11/20/2011 12:52 PM
Guys, both of you are right! Propane as a gas is the low number at Standart conditions, LPG, so liquid propane, is the high number.
Good Answers: 19
11/20/2011 10:29 PM
Thanks a heap Tompa.
11/21/2011 11:27 AM
It is NM3/hr
Thanks
Good Answers: 75
11/21/2011 9:01 PM
What on earth does NM3/hr stand for.
Normally N is the abbreviation for Newtons which is a measure of force, and upper case M is the abbreviation for Mega which means multiply the units by 106 hr is an abbreviation for hour and what the three is for beats me.
So we have Newton Mega 3 per hour.
Or alternatively the M3 could be a typographical error for m3 which is the abbreviation for cubic metres so we now have Newton cubic metres per hour
Which doesn't make sense either.
Is there any chance you can replace the abbreviations with actual words so we have some idea of what you are talking about.
PS: Keep in mind that Mm and mm in the metric system are different by a factor of 109.
11/22/2011 7:45 AM
Flow Rate is 3-4NM3/Hour
Thanks
ANKUSH
11/22/2011 7:57 AM
THAT IS ROUGHLY 10kg LPG per hour.
Small Furnace.
mm
11/22/2011 9:27 AM
Thanks. Can u pls give me the conversion formula?
Regards,
ANKUSH
11/22/2011 9:55 AM
POSTS #16 AND #38 hold the answer .
Just multiply .
mm
Good Answers: 75
11/22/2011 8:09 AM
What on earth does NM3 stand for?
Good Answers: 75
11/22/2011 8:27 AM
Why is this strand marked off topic????
Good Answers: 75
11/22/2011 8:31 AM
Probably because I've asked pretty much the same question three times now and haven't got a response.
11/22/2011 8:53 AM
Nm3 = " Cubic Metre of Gas at NTP"
NTP IS 20 DEGREE C at Atmospheric Pressure
Should not be marked Off-Topic
Good Answers: 75
11/22/2011 9:18 AM
Aha the fog suddenly clears, so in other words it should be written m3hr-1 or m3/hr at NTP
With the metric system you have to be extremely careful about using upper and lower case letters and which order they are in especially with the first letter which is the multiplication factor. As for the units you use lower case letters unless the units are name after a person in which case you use upper case units.
So for units:
m = metres
N = Newtons (named after Newton)
Pa = Pascals (named after Pascal)
While for prefixes or scaling factors
m = milli or multiply by 10-3
M = mega or multiply by 106
Hence the confusion when first he asks about N/mm2 which is a measurement of pressure then NM3/hr which is technically meaningless.
Good Answers: 75
11/23/2011 7:54 AM
Ta-da!
And you should know (our newbie OP is forgiven this time...) to turn the Off Topic button off before posting....
11/23/2011 8:23 AM
masu -- You are so Precise!
That is the way to carry out sensible discussions in CR4
Lead us kindly light
mm
11/20/2011 8:27 PM
Dear Ankush,
Newton/mm2Kg/cm2BarkPa
1.0000000010.1971621310.000000001000.00000000
Hope above conversion helps you.
Reagads.
Best Regards, srzambre.
Good Answers: 75
11/20/2011 9:48 PM
Except kg/cm2 is not a recognized metric unit.
It basically comes from the old imperial system of measurements where pounds were used to measure both force and mass. That's ok for the most part on earth where the acceleration due to gravity is fairly constant but as soon as you start using accelerations other than g it blows up in your face.
In the metric system Newtons are the units used to measure force while kg are units of mass, therefore mass per area becomes a meaningless measurement.
Unfortunately people that don't understand the metric system simply convert pounds to kilograms (1 pound mass = 0.4537 kg) and square inches to square centimetres ( 1 in2 = 6.4516 cm2) and think they have converted an imperial pressure into a metric pressure.
Instead you have to convert pounds force into Newtons ( 1 lbf ≈ 4.448222 Newtons) and square inches into square metres ( 1 in2 ≈ 645.16 x 10-6 m2). Also instead of using the base units of Newtons per square metre the base unit is named after Blaise Pascal and as such is called a Pascal or Pa for short.
Good Answers: 19
11/20/2011 10:34 PM
An elephant is a mouse built to government specification. Hahahaha. Hpe you diod not have Pakistan on mind because the built elephant will be only on a paper .
11/20/2011 11:28 PM
You appear to be putting your own ignorance on display! Masu's comments are absolutely correct, and nothing to laugh at.
Good Answers: 19
11/20/2011 11:37 PM
Sorry you make mistake. I clicked off topic. My comments has nothing to do with what Masu wrote. i agree 100 % to that and i am sorry if I gave a wrong picture otherwise.
I just liked his "elephant" thing at the bottom and laughed on this (NOT HIS COMMENT) because this so how true in this part of the Country with corrupted ministers and commented him on that.
11/21/2011 12:22 AM
Oops! Sorry. I had the impression you were one of those who think units are unimportant...
Good Answers: 75
11/20/2011 11:58 PM
The other half of the elephant joke is that a mouse is an elephant built to a government budget.
Good Answers: 102
11/20/2011 10:43 PM
This is not a pressure problem. It is a "quantity" problem.
Regarding the conflicting density figures.....
I have found sources quoting both these figures. They can't both be right?
Good Answers: 19
11/22/2011 7:00 AM
Will you guys give me a GA on Posts # 12,13 & 17 and close this Title. After # 17 there is nothing else authentic. multiply the /L x 1000 = m3/hr.
Good Answers: 19
11/22/2011 9:54 AM
I was joking on the GA. Thanks
Register to Reply 49 comments
ANKUSH JAIN (4); dhayanandhan (1); dkwarner (5); ducon (10); English Rose (5); masu (7); MUKULMAHANT (7); PWSlack (1); srzambre (1); Tompa (3); Tornado (2); Wal (3)
