Previous in Forum: Bends on a pipeline   Next in Forum: Use of high strength bolts in low temperature
Engineering Fields - Mechanical Engineering - I am here to help!!
Possible reasons for problem with silver plating on copper component
04/27/2007 7:36 AM
We are facing some problem with silver plating on copper component.
For silver plating first the component is dipped in AgCN for adding some layer of Ag on the copper so that in the next process when copper is dipped in AgNo3 solution, copper is not lost in AgNo3 & only silver is deposited onto the surface.
Now it is found that when the copper is treated in AgCn, then along with Ag some amount of copper is also getting deposited on the surface, which is not desirable.
What might be the reason for this?
Good Answers: 120
Re: Possible reasons for problem with silver plating on copper component
04/27/2007 11:34 PM
the first solution is depositing some Ag and picking up a little copper and later that copper get deposited. AgCN and Cu(CN)2 are not simple as we draw them here. they are cyanide complexes.
http://www.pfonline.com/articles/pfdmorrissey01.html
http://www.google.com/search?hl=en&q=%22cyanide+complex%22+%2B%22silver+plating%22&btnG=Google+Search
Per Ardua Ad Astra
04/28/2007 3:55 PM
Use a solution made from Silver cyanide disolved in potassium cyanide this is made by adding potassium cyanide to silver nitrate solution until precipitation ceases and the disolving the precipitate in excess of potassium cyanide ands diluting until the solution contains about 2oz of silver per gallon. If the silver anode darkens there is not suffient free cyanide. In siver plating first dip in a weeak solution of nitrate of mercury.
All the best and wear gloves and don't forget to was well. PS. Cyanide is easily absorbed through the skin. Keep some ferrous sulfate solution close by in case of spills and splashes. Cyanide has a great affinity for iron. Good plating.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 120
04/28/2007 4:33 PM
Make sure you use distilled water for these solutions.
It is fairly toxic.
Very toxic by inhalation, in contact with skin and if swallowed.
Potassium cyanide - LD50/oral/rat = 10 mg/kg
Hydrogen cyanide - LD50/oral/mouse = 3.7 mg/kg
So a 100 Kgm rat would be one hell of a rat that would take 1 gram to kill 50% of the subjects. mammals and man will all have similar sensitivity to cyanide.
http://www.emedicine.com/emerg/topic118.htm
Per Ardua Ad Astra
Hobbies - HAM Radio - VE6LDS Popular Science - Weaponology - New Member Canada - Member - New Member Engineering Fields - Nuclear Engineering - New Member
04/29/2007 12:39 PM
Just to emphasize the point, hydrogen cyanide was used in the gas chambers in those states that used them.
Semi-retired systems analyst, part time Ham radio operator, full time grandfather.
04/30/2007 7:54 PM
Yes an evil way to go. Sodium cyanide into heated sulphuric acid.
04/28/2007 7:40 PM
Sorry for the howlers some how the mistakes always appear automatically even after spell checking! But the info is good.
Register to Reply 6 comments
aurizon (2); BrainWave (3); The_curious_one (1)
