Previous in Forum: Gusset Plates Location, will it Make a Difference?   Next in Forum: Pallet Handling in Machine Shop
From Chain to Belt Roller Conveyor
11/22/2011 2:24 AM
i am required to replace the old chain conveyor with belt and roller conveyor. one of the sections has the following parameters:
belt widith = 940mm, 4800mm horizontal length and 13300mm inclined at 26.84 degrees. clay is the transported material. HELP WITH THE DESIGN PROCEDURE.
Re: from chain to belt roller conveyor
11/22/2011 2:42 AM
How dense is the clay? How much weight per time must be conveyed? Do you already have a method for holding the belt down where it transits from horizontal to 26.84°? Is there some special reason why the belt can't be sloped the whole way? What is the consistency of the clay?
11/22/2011 4:22 AM
i will confirm the material density and flow rate when i go on site. there isnt enough space to slope the belt the whole way-26.84° cant be avoided. any checklist i can use to collect all the neccessary data?
11/22/2011 4:30 AM
<...checklist...>
See #1 above.
Good Answers: 21
Re: From Chain to Belt Roller Conveyor
11/22/2011 7:46 AM
There are a lot of ways to make this happen. My suggestion is to contact a belt supplier. I have used many types of incline belts that run materials at much more of a slope then your proposing. Make some contacts with local belt suppliers or goggle for information.
11/22/2011 8:48 AM
Why waste your time coming here when you will just have to go through all this again when you finally select a belt supplier.
Pick 3 potential suppliers, tell them you do not know anything about designing a conveyor system, give them all the information you have and ask them for their recommendations. Cut out the "middle-men", us.
11/23/2011 8:57 AM
GS has quite a few belt suppliers (http://www.globalspec.com/SpecSearch/Suppliers?comp=2411&frmtrk=fpsf) you can probably find one near you.
Register to Reply 6 comments
fixitorelse (1); Gift71 (1); lyn (1); Paddy O'Flanigan (1); PWSlack (1); Tornado (1)
