Previous in Forum: Nyloc Nut vs Plain Nut   Next in Forum: What ASME Standard is used for reference?
Need help with control valve selection
04/27/2007 10:45 AM
hello guys would you tell me how to get ASME f 1565 and ASME 16.34 for design contol valve and pressure reducing
and thank you for help
Re: Need help with control valve selection
04/27/2007 12:37 PM
The legacy of the digital age is that of segregation through differing formats. - HerbVic
04/28/2007 1:37 AM
First make up your mind:
  • You Want " how to get ASME f 1565 and ASME 16.34" OR
  • You Want " design contol valve and pressure reducing"
Come back to CR4 with full problem statement if you want to Optimally Design/select Control Valve for a particular application of pressure Reduction.
Go to ASME-USA -- for ASME's codes.
Cheers
04/28/2007 10:04 AM
The following codes & standards are related to valves & control valves :
ASME B16.34 Valves-Flanged, Threaded, and Welding Ends.
ISA RP75.06 Control valve manifold designs recommended practice.
ISA RP75.03 Face-to-face dimensions for flanged globe-style control valve bodies (ANSI classes 125, 150, 250, 300 & 600).
ISA RP75.04 Face-to-face dimensions for flange less control valve bodies (ANSI classes 150, 300 & 600)
(ASME: American Society of Mechanical Engineers & ISA: Instruments Society of America)
11/28/2023 4:37 AM
<...control valve selection...>
Open a dialogue over the telephone with the local friendly valves distributor, and get that body to help.
Register to Reply 4 comments
Abdel Halim Galala (1); HerbVic (1); MUKULMAHANT (1); PWSlack (1)
