Previous in Forum: Simple Fan Engineering Question   Next in Forum: How Much Diesel Required for Heating Up Water??
10 comments
Spiral Welded Fire Water Service Pipe Limitation?
11/23/2011 8:58 PM
Are there any limitations on using spiral welded pipes in underground fire water service? The line size is 10" and we use raw water as fire water.
BR
Aqeel
Pathfinder Tags: Fire Water Pipe Material
Re: Spiral Welded Fire Water Service Pipe Limitation?
11/24/2011 3:45 AM
What materials - polypropylene, for example?
11/24/2011 4:47 AM
Thanks for reply. Carbon Steel is the material A53 Gr B.
Is there any code restriction on using it.
11/24/2011 11:16 PM
I have not seen CS line used in underground fire water service. The more common materials are HDPE or cement lined ductile iron. Corrosion will be a huge issue for a CS underground pipe.
As for the code, have a look in NFPA 24?, or your local codes.
Continuous Learning
Good Answers: 18
11/25/2011 6:09 AM
Since it is a flow line and with low pressure, you can use it for your fire water service.
Make sure that, there are no leaks in the weld joints.
sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
11/25/2011 7:21 AM
We have used it for Tower water low pressure in the steel mills the outside is coated the medium is chemically treated as not to corrode the CS. Not sure why it would not work for a fire water service as long as its coated outside, there may be issues, as stated, with inside corrosion depending on the nature of the raw water used.
Good Answers: 102
11/25/2011 8:02 AM
What is the expected service life for this installation?
11/25/2011 11:55 AM
for us economy is a big issue so we will wrap a tape coating on this pipe. I want to know if there is a limitation or restriction by any code or regulatory authority
11/25/2011 12:23 PM
Economy along with labor I presume? Manually wrapping the pipe is labor intensive you can buy spiral pre-coated pipe.
11/25/2011 1:17 PM
In our refinery the pipeline of fire water system of the storage tanks have been replaced HDPE pipe (underground) and carbon steel (aboveground). When you use raw water as fire water, you need to coat the carbon steel pipe both inside and outside. If you use 'dry pipe' (pipeline which is temporarily filled) maybe you don't need any inside coating.
Good Answers: 102
11/25/2011 10:01 PM
Can you make it the supplier's responsibility to provide code compliance citations for your application?
Register to Reply 10 comments
muhammad.aqeel (2); pipeit (2); PWSlack (1); SRIDHAR (1); sv13 (1); Wal (2); znpyro (1)
