Previous in Forum: Derating of Busbar In Its Sizing.   Next in Forum: Why multi-core HV cables are not colour-coded?
How I can synchronize
11/24/2011 12:09 AM
Dear Friends
I have four no's of DG genset. Two are FG Wilson and two are Cummins power. All of gensets are Electronic injector controlled (ECM/ ECU). Unfortunately I don't have any wring/ Electrical diagram of Cummins power genset. I want know how we can synchronize and load share between FG Wilson and Cummins power genset. I want to use easy gensen 2500/ 3200 controller. It will be appreciated if u tell me how I will be connected for speed / voltage bias for Cummins power genset.
Thanks
Hanif
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: How I can synchronize
12/01/2011 7:28 PM
Mostly the new cummins genset model have the controller called PCC, and they just only in baseload application if syncronize with existing. We need more data from your cummins genset, PCC ? engine model ?
One system
Reply to Forum Thread
