Previous in Forum: What ASME Standard is used for reference?   Next in Forum: Dent Removal procedures
Proportional pressure controller and gas flow control
04/27/2007 3:54 PM
Can a proportional pressure controller (PPC) be used with a fixed orifice to control a steady flow of argon?
If there is an opening at the end of a tube further down, which will be immersed in a liquid so as to vary the backpressure, will it effect the flow or will the flow still be kept constant?
What types of flow controllers for inert gases are the most compact?
Are there any websites available on modeling and calculating values of pressure systems?
Thanks.
Re: Proportional pressure controller and gas flow control
04/28/2007 1:51 AM
Yes, you can use a proportional pressure controller to control the pressure. Controlling the prssure will automaticaly controll the flow through a constant size orifice.
yes back pressure will also affect the flow through the orifice the flow gets minimized as back up pressure builds.
05/09/2007 3:58 AM
Why is the orifice there? A pressure controller controls pressure, not flow, and flow and pressure are inter-related, especially if there is a changing pressure at the end of the pipe downstream of a pressure regulating device; one could stop the flow completely and the pressure would remain constant.
Consider the use of a needle valve and a variable area flowmeter as a possible alternative solution, like on the cylinders of argon used in inert gas welding set-ups, especially where the set-up is manned, perhaps?
Register to Reply 2 comments
