Previous in Forum: Oil Separators   Next in Forum: Mezanine Floor Sound Isolation
ANSI Flanges #900 & #1500
11/25/2011 4:24 AM
we use flanges 900 and 1500 in place of each other
is it required to be stamped on the flange 900/1500
or no 900 at all
or absolutly we use 900 in place of 1500 and opposite
Pathfinder Tags: thank you for your time
Re: ANSI fanges #900 ל
11/25/2011 4:44 AM
One hopes you haven't ruptured a 1500 psi pipeline yet by using only a Class 900 flange in it.
If the flange is dual stamped 900/1500, it can be used in either class of piping.
If stamped 1500 only, it can still be used in either class of piping.
If stamped 900 only, it cannot be used in class 1500 piping.
11/25/2011 10:49 AM
Thank you for your reply
but i have something with the code ,the two flanges have the same dimensios
which means that 900 can be replaced by 1500
or there is another factor than the dimensions
regards
11/25/2011 10:55 AM
It might also depend on the material and method of manufacture.
Are you sure ALL the dimensions are the same? (Not just bolt pattern, but thicknesses, tapers if any, and fillet radii.)
11/25/2011 11:00 AM
Sorry,i forgot to tell you that they are identically in the code but only for 1/2" to 2 1/2" only
regards
Register to Reply 4 comments
