Previous in Forum: Test On the Underwater-Current Flow Along the Eastern Coastal Waters of Negros   Next in Forum: How Many Retailers Does It Take to Change a Lightbulb?
Stirling Engines
11/26/2011 2:03 AM
I search for sterling engines 1-10 kw for solar applications and/or waste heat recovery.
Re: stirling engines
11/26/2011 2:10 AM
There is quite a hobbyist field in Stirling engines in this range. For example, Google "5hp Stirling engine," and you should get some videos and plans.
Waste heat recovery is typically at too low temperature differentials to be very effective; I think concentrated solar collection has better potential.
Re: Stirling Engines
11/26/2011 11:58 PM
Solar can work OK, waste heat depends on the source temperature, etc.
Problem with getting hot air (Stirling is a specific design) engines to run efficiently is you need to pressurize the working fluid and air isn't a good choice. The rare gasses that work well tend to leak right through metal so you need to move to ceramic.
Philips did a lot of work on hot air engines back in the 70's.
It was burning when I put it down!
11/27/2011 3:44 AM
Google = stirling engines
Regards JD.
11/30/2011 3:04 AM
Use Google (usual disclaimer - other internet search engines are available).
12/02/2011 4:24 AM
Do you want to use the Stirling engine for waste heat recovery, or power the engine with waste heat? Attention to waste energy recovery should start with designing your question to allow efficient answers and less bs entropy. (it can get very deep).
jdretired (1); mrehmus (1); PWSlack (1); Tornado (1); woodpower (1)
