Previous in Forum: Windows Virtual PC XP Mode   Next in Forum: NX Siemens-Pseudo Automation Code Programmer
Computer Screen Width
11/26/2011 6:06 PM
I use explore as a search engine. When ever I click on a link The screen that comes up is only 1 1/2 inches wide. I have had this happen before and for some reason It stopped. I have tried to find a solution but so far I have not. Can you help?
Re: Computer screen width
11/26/2011 10:33 PM
Well, the obvious thought is to click and drag the window to fill the screen to the size you want, then close the window. The next time you open a window it should be the same size as the size it was when you last closed it.
Re: Computer Screen Width
11/27/2011 12:49 PM
That is obvious and that is what I did without success. Then I closed out by clicking on the red X top upper right. I signed on and the same thing occurs. Thanks for answering the question.
11/27/2011 5:41 PM
Problem solved
Register to Reply 3 comments
