Previous in Forum: What is Slope of an Instrument   Next in Forum: Optical Modem in ABB DCS
Speed Measurement
11/27/2011 5:03 AM
I want to know the difference between key phasor and pickup, which signal should i give to my governor.
Re: Speed Measurement
11/27/2011 9:17 AM
I think there is a fundamental misunderstanding of the language here.
Keyphasor® Transducer
A transducer that produces a voltage pulse for each turn of the shaft, called the Keyphasor® signal. This signal is used primarily to measure shaft rotative speed and serves as a reference for measuring vibration phase lag angle. It is an essential element in measuring rotor slow roll bow or runout information.The Keyphasor® transducer is typically a proximity probe (recommended for permanent installations in which the probe observes a physical gap change event), an optical pickup (used for temporary installations in which the pickup observes a change in reflectivity event) or a magnetic pickup. Keyphasor® is a Bently Nevada registered trademark.Mechanical RunoutA noise component in the output signal of a proximity probe transducer system; a probe gap change which does not result from either a shaft centerline position change or shaft dynamic motion. Common sources include out-of-round shafts, scratches, chain marks, dents, rust or other conductive buildup on the shaft, stencil marks, flat spots, and engravings.
