I want to do surface finishing on a clamp, the material of clamp is steel, but requirement is after zinc plating both side of clamp should be covered with plastisol & plastisol should not disperse on plastisol uncovered area, which should be as it zinc plated.So please tell me process how to do it? the sequence of process, first do zinc plating & then plastisol or vice versa?
