Previous in Forum: Lift application using AC Drives(VFD)   Next in Forum: Maximum Demand in a Single feeder at 11kV feeder
Use of Breakers
12/01/2011 2:39 AM
Dear Frds,
I want to know the use of HT Breaker and LT Breaker?
and
What is defference b/w LT and HT lines?
Re: Use of Breakers
12/01/2011 3:27 AM
HT breakers for HT lines; LT breakers for LT lines. Local Codes may have different distinctions between high voltage/tension, medium voltage/tension, and low voltage/tension. The higher the voltage, the thicker the insulation and/or the wider the separation between conductors; also larger arc gaps for switching components.
Good Answers: 170
Re: Use of Breakers
12/01/2011 3:32 AM
From your name, I assume you are from India. And, as per the Indian Electricity Rules, 1956, Rule No. 2 (av):
Low Voltage is not exceeding 250V
Medium Voltage is not exceeding 650V
High Voltage is not exceeding 33000V and
Extra High Voltage is exceeding 33000V
And, a breaker which is used in High Voltages is called HT Breaker and a breaker which is used in Low Voltages is called LT Breaker. So also for the HT and LT Lines.
Register to Reply 2 comments
