Previous in Forum: Use of Breakers   Next in Forum: Electrosctatic Phenomena
8 comments
Maximum Demand in a Single feeder at 11kV feeder
12/01/2011 2:43 AM
Hai,
I want to design a substation of 11kv/433V with maximum demand 4500kVA. But the MRS from which I want to take 11kV incomer feeder having only one spare feeder of 1250A VCB Panel. So my doubt is whether a single feeder is sufficient to meet my Maximum Demand as 4500kVA. The Client is under Central Electricity Authority and not comes under local electrical inspectorate, and the location is Kerala. In Kerala, Kerala state Electricity regulatory commissions (KSERC) rule for KSEB is the maximum contract demand for a new single connection is limited to 3000kVA. So my doubt is that whether in any IS standard specifying any maximum demand for a single feeder at 11kV voltage.
Kindly help me....
Egypt - Member - New Member Engineering Fields - Power Engineering - Pain and Joy
Re: Maximum Demand in a Single feeder at 11kV feeder
12/01/2011 2:52 AM
it appears that the current for 4500KVA at 11KV will be around 400 to 500 A if the feeder can tolerate 1250A , so it should be O.K to use it for 500A
12/01/2011 3:19 AM
From this, and the other question about trench requirements, it seems that Kerala needs to update its electrical standards. Maybe more emphasis on technical issues, and less on restricting larger facilities. [??]
Good Answers: 170
12/01/2011 3:29 AM
I second your opinion! Kerala Electrical Inspectorate Authorities are unreasonable in thier demands. They need to update themselves.
12/01/2011 3:32 AM
Interesting...I was sort of guessing, but I thought the clues were pretty good.
Good Answers: 170
12/01/2011 3:29 AM
Did KSERC give a technical resaon for such restriction on MD?
Good Answers: 181
12/01/2011 11:26 AM
Your loading would be 236A at max loading of 4.5MVA. So the 1200A breaker is well on top of the job. The only thing I would be concerned about is the reliance on one feeder.
12/01/2011 11:56 PM
Hi,
Here 11KV side don't have any problem to supply 4.5MVA demand. But, 433V side may have problem considering the FLA and Short circuit current. FLA around 6000A and short circuit amp approx.86kA (considering 7% impedence). 4.5MVA transformer with 433V secondary and 7200A, 433V LV side breaker (100KA rating) are not readily availble in the market. This may be reason for the restriction.
Thanks,
Mari.
12/02/2011 4:12 AM
Dear Mari,
This is the exact reason why there is restirction of Maximum Demand in a particular voltage level.The same is applicable also in respect of the transformer capacity of Utility company from where H.T. power supply is providing.
Thanks,
Manindra
Manindra
Register to Reply 8 comments
electricalexpert65 (2); manindra (1); Mariappan (1); mona sayed (1); TonyS (1); Tornado (2)
