Previous in Forum: Stupid Kitty   Next in Forum: Platinum Recovery from Spark Plugs
19 comments
Tonnie
12/03/2011 5:15 AM
Hi guys. My light truck has a problem of breaking axle studs after every 500kms. What could be the cause? and how can I rectify it?
Re: tonnie
12/03/2011 5:45 AM
It would probably be impractical to redrill and retap for larger studs, but maybe you could look for stronger stud material.
Good Answers: 183
Re: Tonnie
12/03/2011 7:21 AM
Send a picture of broken studs it could help to find the best solution.
It could be possible that you do not tighten them correctly or that the nut gets loose.
The more informations you send the better will be the answer.
Re: Tonnie
12/03/2011 9:02 AM
This usually happens because lugs are loosening up...or studs were not fully seated...
Good Answers: 62
Re: Tonnie
12/03/2011 11:19 AM
This can also happen because we now have two different stud types in the US. Are you running stock factory wheels?
Re: Tonnie
12/03/2011 8:03 PM
What is your application? Street, off road? Are you torquing to manufacture specs? Are you running stock wheels or offsets? Are you using a thread lock? Are you going back after a few KM's and checking torque?
Re: Tonnie
12/04/2011 12:45 PM
The tapered end goes on first!
Re: Tonnie
12/03/2011 10:49 PM
Make certain that you are using lugnuts compatable with the wheel (rim). If the wheel is not factory original, it may require a special taper on the shoulder of the lug nut. There are many different styles. I've seen this with after market wheels using oem lug nuts. Good luck
Re: Tonnie
12/03/2011 11:40 PM
Have the original wheels been changed to an aftermarket wheel?
Why do i ask?
Maybe the hole centres are close but not right.
Maybe the nut seat does not match the wheel hole seat.
Are you in fact talking about the studs that hold the wheel on, or, the studs that hold the axle into the hub?
A picture speaks a thousand words.
Use windows picture viewer and resize your picture to a smaller size to suit a web page.
Good Answers: 102
Re: Tonnie
12/04/2011 12:49 AM
As already suggested by the esteemed panel and, are you overloading the truck by any chance?
Is that 500km on smooth roads or thundering through rough terrain?
Hard suspension, tyre over inflation, crappy replacement studs...
Re: Tonnie
12/04/2011 2:02 AM
i'm not sure if you mean the bolts that mate the axle to the hub or the lug nut studs. does the truck have posi-traction? is the truck a 350 model or above? are you running factory wheels? i need more information.
Re: Tonnie
12/04/2011 8:31 AM
When did this failure start? What changes were performed prior to the failures? Do a root cause analysis to try to come up with a possible cause. I have had many bolt failures due to improper heat treating so when replacing ask for a mechanical certificate on the studs. Not always possible but worth the effort. Lets see some photos for more informed diagnosis.
Good Answers: 58
Re: Tonnie
12/04/2011 10:29 AM
Avoid potholes........especialy the ones bigger than your truck
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
Re: Tonnie
12/05/2011 3:07 AM
This will be happening because the PCD of the wheel does not match the PCD of the hub.
Somehow you've got wheels which do not match the hubs. Introduces moments to the studs, and high speed flexing does the rest.
I had the identical problem, years ago, when installing, by mistake wheels from an earlier model vehicle, and didn't know the manufacturer changed the PCD on the later.
Lucky to be here really. The vehicle shed the wheel at just under 100mph. Studs sheered clean off.
Cheers,
Stu.
"Nothing, is as it seems." Dr Wally.
Re: Tonnie
12/05/2011 3:19 AM
As in, say, 100mm ≈ 4", but 100mm ≠ 4" exactly?
Re: Tonnie
12/05/2011 3:26 AM
Yes, that's the kind of thing.
In my case we had metricated hubs and imperial wheels.
Nominally 4x100, but actually 4x4".
Hope this helps.
Cheers,
Stu.
Re: Tonnie
12/05/2011 4:40 AM
You might just have hit the proverbial "Nail on the Head" with your comment.......
4" is actually 101.6mm, that is QUITE a difference!!!
Re: Tonnie
12/05/2011 5:23 AM
Tonnie, where are you?
Re: Tonnie
12/05/2011 5:25 AM
That should read Anthonyqmy where are you?
Re: Tonnie
12/07/2011 1:03 AM
Some feedback would be good.
What did you eventually find?
Stu.
Register to Reply 19 comments
AKdude (1); Andy Germany (1); Anonymous Poster (1); edignan (1); Fredski (2); JIMRAT (3); KJK/USA (1); nick name (1); roy hammy (1); SolarEagle (1); Stueywright (3); Tornado (2); Wal (1)
