Previous in Forum: Platinum Recovery from Spark Plugs   Next in Forum: Expensive Motorway Pile-Up in Japan
Mini V12 Enjin
12/04/2011 6:51 AM
This is an excellent video showing the creation of a miniature V12 engine:
http://www.wimp.com/tiniestengine/?mid=5443
DQ OR DQ NoT. XeR IZ NO TRi. - YODU
Pathfinder Tags: craftmanship mini engine
Re: Mini V12 Enjin
12/04/2011 7:24 AM
Nice find--that's a cute little devil! (Sort of a Cadillac version of Thimble Drome.)
Re: Mini V12 Enjin
12/04/2011 8:44 AM
Very nicely done. I didn't see any spark plugs; obviously there are no ignition wires, so I assume it 'runs' off compressed air rather than actually having internal combustion take place. Still, very nice.
Re: Mini V12 Enjin
12/04/2011 9:17 AM
Check this one out..
This miniature four-stroke V8 engine has a 1.000-inch bore, 0.900-inch stroke, 9:1 compression ratio, 12,000rpm max., rotary sliding vanes (supercharger), dual WALBRO carbs, dual electronic ignition, and a two stage dry sump oil system.
http://www.techeblog.com/index.php/tech-gadget/incredible-mini-sized-engines
Re: Mini V12 Enjin
12/04/2011 11:25 AM
I noticed that the machinist was using a real calipers and mic.
Good Answers: 62
Re: Mini V12 Enjin
12/04/2011 11:36 AM
Both very cool!
I cannot imagine the first completed in 1200 hours.
I'd be a lifetime.
edignan (1); lyn (1); SolarEagle (1); Tornado (1); Usbport (1)
