Previous in Forum: Proposal for Hardware Project   Next in Forum: Refrigerant Air Dryer Problems
17 comments
Pipe Stress Analysis - Pig Launcher
12/04/2011 7:27 AM
I am doing stress analysis for natural gas plant which has part of under ground pipe and connected to above ground equipment( pig launcher), i got output which has the code compliance of 40% of allowable stress and the vertical displacements are with in 5mm but the force and moments are too large of 100000N at pig launcher inlet i really surprise and need help to balancing this force and moments, please some experts can help me?
Re: Pipe Stress Analysis - Pig launcher
12/04/2011 7:50 AM
Pig launcher? If you're talking about a simple ham grenade you might find some people here who will help you. But if you're involved in a bacon of mass destruction, or a swine flew attack, you probably won't get much help.
12/04/2011 9:01 AM
Yeah,,that can be a problem...
12/04/2011 11:04 PM
The OP is not talking of a Pig or Bacon.
He is talking of PIG -oil country jargon for a traveling brush which scrapes the inside of a Oil Pipeline -- removes accumulated Waxy solids ---
Basically he is puzzled at his results .
It is his Poor stipulations which is showing fantastic stress buildup.
He must introduce the plastic flow in metal beyond yield point . Then all mystery will vanish.
12/04/2011 11:31 PM
Then I will send the brush man...
12/04/2011 9:03 AM
To continue with the ham parlance, it seems that you have bitten off more than you can chew.
Maybe you should stick with launching pumpkins.
"Big 10 Inch" takes a world record shot in Moab, Utah, September 9, 2010
Good Answers: 114
12/04/2011 9:33 AM
Say 23kips.
I have no expertise in this, but doesn't the pig get pushed along with the product? or is this for cleaning the pipe? How big is the pipe?
12/05/2011 8:21 AM
dear sir
the pig trap is used for cleaning and it is connected by a 28 inch valve and the line immediately connected with buried piping. i feel the huge force and moments are from buried pipe line
may i consider the pig inlet nozzle as an non-anchor since the other end is buried and i feel the pipe has no enough length to have flexibility.
DESIGN CONDITION:
PRESSURE : 50BAR
TEMP: 50°C
OPERATING CONDITION:
PRESSURE: 40BAR
TEMP: 38°C
MATERIAL
28" PIPE: API 5L X65 SAW
24" PIPE: API 5L X65 ERW
please share your opinion
thanks.
12/05/2011 9:33 AM
Unless you send:
  • Piping Schematic Drawing
  • Physical Photograph
  • Point marked-- where your worrying stress concentration is
Nobody will be able to suggest/help/share opinion
MM
Good Answers: 179
12/04/2011 10:36 AM
I seem to remember reading something about "Pigs flying"......
(Geee, I just couldn't help myself!)
Good Answers: 114
12/04/2011 11:55 AM
I cast my pearl of knowledge before....
Re: Pipe Stress Analysis - Pig Launcher
12/05/2011 12:20 AM
please refer FORMULAS IN STRESSES AND STRAINS by ROARK.
P.M.Ramakrishnan
Good Answers: 34
12/05/2011 2:17 AM
ASME B31.8 Chapter III and IV
12/05/2011 3:19 AM
(PIG = Pipe internal Gauge)
I think you have to absorb all stresses in your pipeline design so the launcher nozzle will NOT be stressed.
This is common in such cases - we are doing it many times.
12/05/2011 3:09 PM
PIG=Pipe inspection gaget or gage.
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
12/06/2011 12:21 AM
OK - thanks!
12/06/2011 8:11 AM
PIG doing a Delta ID measurement that I developed for the pipe industry.Ron
12/06/2011 8:44 AM
Great photo...
Interesting!
Register to Reply 17 comments
CaptMoosie (1); lyn (1); MUKULMAHANT (2); P.M.Ramakrishnan (1); passingtongreen (2); Rajcs82 (1); ronclarke (2); SolarEagle (2); stargan (3); Usbport (1); Whitephone (1)
