We've finally got some progress to show to you guys. We've been busy with work, school and many side projects but my dad recently got back to machining and buying pieces for the prototype.
He ordered and cut the wrist pins that connect the rods to the mounts on the outer housing. These pins still need cross holes to be cut for oil to flow through the rod.
He has also received a quote to chrome plate the sealing plates and
sleeves. The plates are the surfaces that the side and corner seals
slide across and the sleeves are the surfaces that the apex seals slide
across. You can see the ports cut into the sleeve in the picture. The
plates and sleeves are currently machined over-sized so that they can be
ground down to size and then chrome plated.
My dad has also ordered the apex, side and corner seals. He is
keeping a kind of blog at the DRE site in the comments under the
video. He is keeping track of his day to day progress. I will still try
to post updates here from time to time.
On a side note, we finally got my bug motor running (we've been
making stabs at it since January) and I plan to put it into my bug of
the holidays. You can see us cranking it up here.
