Previous in Forum: Fuses   Next in Forum: AC Generators 3 Phase
8 comments
Hot Hot?
12/08/2011 10:20 AM
I need to provide the tools and materials for techs on our production line to use heat shrink tubing. Does anyone know exactly what temperature heat shrink tubing "shrinks" at? I'd like to find a heat gun that operates in that range to reduce the possibility of burning the tubing, wiring, or anything else.
Everybody's gonna want one.
Re: Hot Hot?
12/08/2011 10:57 AM
Before going any further, did you look to see what the heat shrink manufacturer recommends? Either in print or via their website?
Re: Hot Hot?
12/08/2011 11:08 AM
Actually still waiting for a reply on that.
Good Answers: 804
Re: Hot Hot?
12/08/2011 11:21 AM
It's going to vary by manufacturer and the type of tubing, so you will have to wait. Did you try the website of your supplier?
Good Answers: 73
Re: Hot Hot?
12/08/2011 12:39 PM
If you're not going to automate right away, then trust the techs. Most of the time this is a learned sort of thing that one picks up quickly through observation.
Your task involves temperature, proximity to the source, and time. So, it will only require a little training to perfect the skills necessary.
Obviously there is a trade off for time and temperature. The more paranoid you are, the longer it will take. Don't do your training on products you intend to sell. Practice on some scrap pieces first. It is really quite easy.
Lastly, make sure that hot surfaces are not within easy access or have your techs where protective gloves while doing that part of the job.
Re: Hot Hot?
12/08/2011 1:25 PM
The products I use are in the 250-350 degree range. I was looking for a heat gun designed to operate at less than 500, but no luck. Looks like I better start to work on another training program!
Thanks for all the feedback
Re: Hot Hot?
12/08/2011 2:03 PM
My experience with heat shrink is there are three main types requiring three different heat sources for ease of application
1) Cigarette lighter
2) Standard two setting hot air gun (although you can buy multi-heat setting heat guns)
3) Gas blow torch
Again you can buy multi-setting heat guns (try your local mega or commercial engineering supply store).
Alternatively do what most of us do and.....move the heat gun further away! Most heat shrink has a wide temperature range it can handle so with a little bit of training a standard two-setting heat gun can be used on virtually any heat shrink (even thick wall, but yes it will take time and very low temperature heatshrink with a little care).
Re: Hot Hot?
12/08/2011 2:46 PM
This might help to give you an idea what you need to know...
http://cableorganizer.com/heat-shrink/
Hobbies - Musician - Tube Amps Only Please!
Re: Hot Hot?
12/09/2011 10:27 PM
A hot hand Hair Dryer will work which is about the minimum to shrink. Though use a variac and experiment with the AC voltage to see what works best and then calculate the Watts. A Tech wanted to shrink a nylon waxed cord around a bundle of Kynar 30 guage wire wrap wire and she did NOT believe what I told her that the Kynar (insulation) would melt. Guess what? She looked under the wrapped wire and I saw silver wire all shorted due to not following my instructions.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 8 comments
jack of all trades (1); JRaef (1); maveric_manic (1); NotUrOrdinaryJoe (1); retrotech (2); SolarEagle (1); Usbport (1)
