Previous in Forum: DC-DC Convertors   Next in Forum: Induction Lamp
14 comments
Fuse Selection
12/09/2011 12:41 AM
How to select the fuse rating for the particular application or for the motor ?
how to select the circuit breaker and relays for the individual equipment?
Re: Fuse selection
12/09/2011 12:44 AM
Consult local electrical Code. If none, consult some other local/regional electrical Code.
Re: Fuse selection
12/09/2011 12:46 AM
Go to school.
Consult the proper code.
Google NEC.
Ask an electrical technician.
Google fuse and circuit breaker sizing.
Good luck.
Re: Fuse Selection
12/09/2011 3:00 AM
Use British Standard 7671. How about asking Santa for a copy?
Good Answers: 181
Re: Fuse Selection
12/09/2011 5:06 AM
Don't forget to ask for the BGB (green copy).
Good Answers: 170
Re: Fuse Selection
12/09/2011 8:30 AM
by attending a structured training programme on the subject.
Re: Fuse Selection
12/09/2011 9:00 AM
The proper technique is to go to school and learn the fundamentals of electricity. This should teach you which parameters are critical for fuse selection and how to calculate or measure these parameters. This approach will also provide you with a useful skill set in your career, if you do your own homework.
The next technique is to visit fuse and circuit breaker manufacturer's web sites and read the application notes that these web sites have. The problem with this approach is that these sites expects only people that have a fundamental knowledge of electricity in the first place.
The next technique is to hire or pay for the services of somebody who did succeed in doing one of the two above techniques. People you can hire are electrical engineers, electricians, and electrical technicians. Payment should be negociated before the rendering of service. Payment can be in the form of currency, barter, or any of a number different favors. These favors don't have to be salacious, but if you both agree they could be.
So if you go through the effort of learning electricity and how to do your own work, you can become of the receiver of payment.
Good Answers: 70
Re: Fuse Selection
12/10/2011 3:08 PM
GA, well put redfred. It's obvious that this person missed out on the class notes when they covered the subject of circuit protection
Re: Fuse Selection
12/09/2011 10:51 AM
"How to select the fuse rating for the particular application or for the motor ? how to select the circuit breaker and relays for the individual equipment?"
These are not simple questions...First you must determine that you have adequate power supply, that the voltage, hertz rating is correct, then the wiring must be sized to accommodate the anticipated load, with an acceptable margin... then the overcircuit protection can not exceed the wiring capabilities in this application...usually these circuits are shared with other loads, you must determine if the appliance in question requires a dedicated circuit, or will share a circuit with other uses...If this is the case an additional fuse device may be required for the appliance in question... Most electrical appliances have a electrical rating tag attached, but usually these only give a portion of the information needed, you must be able to calculate the rest on your own...Certain grounding or other special requirements exist for certain applications...Motors typically require 2 to 3 times running current on start-up, your fusing must be delay type to allow this but still be close enough to motor load usage to protect the motor, but not so close as to overheat...So you can see this type of work requires a great deal of knowledge and should not be attempted by laypersons, such as yourself...One small mistake can cost the life of an innocent bystander...
Re: Fuse Selection
12/10/2011 8:54 PM
for fuse selection = motor hp x 1.5
Re: Fuse Selection
12/10/2011 9:16 PM
Only for 3-phase motor voltages around 460, and not very precise even there.
Re: Fuse Selection
12/12/2011 11:46 PM
Dear friend,
It should be Motor FLA * 2.5 times will be the fuse rating. This will match TYPE 2 Coordination.
anandcumi@gmail.com
Re: Fuse Selection
12/10/2011 9:55 PM
Its easy to pick a fuse for a motor. Take that one. The one I'm pointing at. It'll work just fine for that motor. Yes, I'm pointing to that motor. Can't you see.
Good Answers: 102
Re: Fuse Selection
12/13/2011 1:22 AM
The function of the fuse is to protect the conductors.
Select fuse according to the conductor size not the applied load.
Conductor selection is dependent on the load.
Good Answers: 19
Re: Fuse Selection
12/14/2011 7:20 PM
Well educate yourself with the link below. Or hire an electrician.
http://www.omega.com/auto/pdf/REF_FuseSizingGuide.pdf
Good luck, and remember the fuse protects the feed not the load.
Register to Reply 14 comments
anand purushothaman (1); dj95401 (1); electricalexpert65 (1); lyn (1); manojadat (1); PWSlack (1); redfred (2); SolarEagle (1); Stedou73ish (1); TonyS (1); Tornado (2); Wal (1)
