Previous in Forum: Parellel Port To USB Connection   Next in Forum: Monitor Resolutions
C# Email Application
12/11/2011 10:13 AM
hi, i want to make an email application through c# n i have debugging error on
"client.Send(mail);"
n em using this code
"using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Web;
using System.Net.Mail;
namespace ConsoleApplication6
class Program
static void Main(string[] args)
SmtpClient client= new SmtpClient("smtp.gmail.com");
client.UseDefaultCredentials = true;
MailMessage mail = new MailMessage();
client.EnableSsl = true;
client.Credentials = new System.Net.NetworkCredential("tousifshaikh.91@gmail.com", "shaikh91");
mail.To.Add(new MailAddress("tousifshaikh.91@gmail.com"));
mail.From = new MailAddress( "tousifshaikh.91@gmail.com");
mail.Subject = "subject";
mail.Body = "body";
client.Port = 587;
client.Send(mail);
" can any 1 help me plz
Good Answers: 62
Re: c# email application
12/11/2011 10:18 AM
A very complete posting of the problem - That helps!
Is it throwing any particular debug error?
12/11/2011 12:07 PM
12/11/2011 7:13 PM
____________________________________________________________
Your coding may or may not be spot-on, but your use of language for communication leaves a lot to be desired - and doesn't lend much confidence to your post. Please refrain from "txtspk", and use English (the language of CR4).
Register to Reply 3 comments
edignan (1); JohnDG (1); SolarEagle (1)
