Previous in Forum: Information at the Speed of Light   Next in Forum: C# Email Application
Parellel Port To USB Connection
12/04/2011 12:43 PM
I have an old Canon Bubble jet printer BJC 1000sp which works on parallel port I have boughta Parallel to USB Adaptor (BAFO make )
with a driver cd.However when i conne ct the message displayed is USB device not recognised. Please help as to how I can make it work.
Regards
Venu
Engineering is an art which makes mans life a wee bit easy.
Re: parellel port to usb connection
12/04/2011 1:20 PM
I don't know if this will help, but I've got some devices installed on a laptop running Windows XP that required the software be installed first (which required a re-start), before plugging in the devices.
12/04/2011 1:40 PM
What o/s do you have? Does it support usb?
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Parallel Port To USB Connection
12/05/2011 8:45 AM
Sometime during the process of "detecting" the new USB/Parallel interface, Windows should have prompted you, asking for a driver. At this point you would want to browse to the disk that came with the adapter.
Did you try to install the driver that came with the adapter? What version of windows are you using? Is the adapter compatible with that version of Windows? Did you read the install instructions?
More questions than answers......... Get back to us with a few clarifications.
Tom D.
Register to Reply 3 comments
SolarEagle (1); tdesmit (1); Usbport (1)
