Previous in Forum: Hydrojet Machine Manufacturing   Next in Forum: Impression Mark on Sheet Metal
Manufacturing - Calculate the OEE/Shift
12/13/2011 12:11 AM
Hi friends
Can you pl suggest me.
In machining section say for example in turning center
How to calculate the OEE/shift if the set up change is more than one and cycle time or no of piece/minute is different.
For example..
In shift A.
Part No A cycle time is 75seconds
Part No B cycle time is 70 Seconds
Part No C cycle time is 95second
Part No D cycle time is 100seconds.
Shift length is 8 hours.
Planned break hours:60min
Down time;80min(Including 4 setup change)
Part No A produced:50 pieces
Part No B produeced:75pieces
Part No C produced:56 pieces
Part No D produed:54 pieces.
In Above example can you pl calculate the OEE.
If you give the brief explanation with example which will be helpful for me.
Re: manufacturing
12/13/2011 3:17 AM
What's the pass mark?
Re: Manufacturing - Calculate the OEE/Shift
12/14/2011 7:04 AM
Hi,
Your OEE for the shift is 68%.
Your Availability for the shift is 71%
Assuming you've no Quality Losses then your Performance is 96%
Total Shift Time is 480mins (8 Hours)
Product Times:
Product Cycle Time Qty Seconds Minutes
Product A 75 x 50 = 3,750 = 62.50 Minutes
Product B 70 x 75 = 87.50 Minutes
Product C 95 x 56 = 88.67 Minutes
Product D 100 x 54 = 90.00 Minutes
Total Minutes is 328.67
328.67/480 = 68% OEE
140 minutes (planned and unplanned) / 480 = 29% downtime = 71% Availability.
OEE is also
AxPxQ = OEE
71% x P x Q = 68%
PQ = 68/71
Hope this helps
Andrew.
Register to Reply 2 comments
