Previous in Forum: Thermal Properties of Air Entrained Concrete   Next in Forum: Electrostatic Dissipative (ESD) Label
Behaviour of Salt Core
12/13/2011 6:05 AM
Dear All,
I have a basic question, which i am confused of so any input or clarification will help me to understand better.
Actually, i have a compacted salt core which is very stable at STP conditions(Non-hygroscopic). Then, I expose the same salt core to pressure ~ 1500 Psi & Temperature of 200 F for a period of 24 hrs (say) and slowly cool-down the temperature to room temp and release the pressure to Atm pressure. My observation is that the salt is going unstable means, I see the surface getting greasy/watery (zooing out some water from the matrix of salt). Which is simillar to hygoscopic salts absorbing water from atm. but my question is why is not happening before i expose the same salt to pressure if the salt is actually hygroscopic.
Am I de-stabilizing anything with respect to the salt core. you inputs are highly appriciated .
bala....
Re: Behaviour of Salt Core
12/13/2011 12:54 PM
By raising the pressure you are increasing the humidity...
http://en.wikipedia.org/wiki/Sodium_chloride
Critical humidity at 20 °C, (68° F)75.3%
