Previous in Forum: Load Unbalance Effect   Next in Forum: 3 Phase Distribution Board With Dedicated Circuit
Reverse Active Energy (kWh Electrical Meter)
12/15/2011 1:29 AM
What is the cause of reverse active energy as measured by a standard kWh electrical meter. I know it is opposiute to forward active energy, but what is the most common cause for reverse energy. Is it to do with syncronisation of Hz between the buss bar and that coming from the main/Gen supply? Your answers will be much appreciated.
Re: Reverse Active Energy (kWh Electrical Meter)
12/15/2011 3:40 AM
Grid Driving the Generatorwhich is now a synchronous motor driving the turbine as a compressor.
Good Answers: 444
12/15/2011 12:48 PM
Actually it depends where the meter is located on the grid. If it is located on the output of a generating station then power is flowing into the station. If it is located on a point of consumption (residence or commercial use) and it is "running backwards" then there is a source of power (solar,wind, diesel, etc.) on the load side of the meter that is producing more power than the facility consumes.
12/15/2011 2:50 PM
This would be most common when speaking of a co-generator setup when power generation is intermittent...A meter can be used to tweak output during peak usage hours and reversed during off-peak hours to maximize output monetarily...
http://www.szstar.com/en/product/product_97.aspx
01/01/2012 11:06 PM
I may be a bit late here.
Reverse energy is a common fact, if there is a generator producing some output power there is a current that may be in phase with the Vac being generated - if another power source is place in parallel and synchronized with the first generator the current in this case will flow toward the fist if the voltage is at a higher level, if there is a load applied to the Vac the load will start receiving energy from both power sources if both are synchronized and in PHASE to each other, if the second power source has a higher Vac voltage then this unit will be supplying the power that the load attached to the circuit is receiving and the first generator is there idling and not supplying power to the load -- This is the basic arrangement used by the power plants to synchronize and to share power when needed .
Register to Reply 4 comments
Anonymous Poster (1); Nando37 (1); RAMConsult (1); SolarEagle (1)
