Previous in Forum: Urgent Help on Brushless DC Drive   Next in Forum: Reverse Active Energy (kWh Electrical Meter)
10 comments
Load Unbalance Effect
12/14/2011 11:12 PM
plz when we have a 4-wire gen. 220/127 A, 131A 50 KVA and we conect 15 KVA 220 V single phase load between L1-L2 and another 15 KV 220 V load to L2-L3 what will be the distribution current in L1,L2,L3 and also the effect on the gen.
thanks
Re: Load Unbalance Effect
12/15/2011 3:07 AM
What is the pass mark?
12/15/2011 7:31 AM
what do you mean?
12/15/2011 8:23 AM
The original poster put up an exam question.
12/15/2011 9:40 AM
Actually it"s not an exam question, really I have a generator 220/ 127 V50 KVA 131A and my load 120 lighting poles [220v,250w/pole] distributed in 1100 m line connected together by a 4*16 mm sq cable and the main supply 380/220V 4wire system ( from city net.), I have to use a gen. with A.T.S. as standby source and I have only the mentioned gen. so I need to know the current values in all lines to check if it" s suitable for the conected cable and the effect of unbalance on the the gen., proposal ATS terminal : [ L3g-N, L2g-L3,L1g-L2 ].
thanks for all
12/15/2011 10:15 AM
Good Answers: 181
12/15/2011 1:21 PM
Line current is easy enough for you to calculate, neutral current is:
In=√((Ia² + Ib² + Ib²) - ((Ia X Ib) + (Ia X Ic) + (Ib X Ic)))
12/15/2011 2:25 PM
Quote"plz when we have a 4-wire gen. 220/127 A V, 131A 50 KVA and we conect 15 KVA 220 V single phase load between L1-L2 and another 15 KVKVA 220 V load to L2-L3 what will be the distribution current in L1,L2,L3 and also the effect on the gen."
Have you heard of vector addition?
12/15/2011 2:31 PM
So KH, are you the imposter Anonymous Poster #1? Why not post the question as KH?
12/15/2011 2:50 PM
KH Quote " Actually it"s not an exam question, really I have a generator 220/ 127 V50 KVA 131A and my load 120 lighting poles [220v,250w/pole] distributed in 1100 m line connected together by a 4*16 mm sq cable and the main supply 380/220V 4wire system ( from city net.), I have to use a gen. with A.T.S. as standby source and I have only the mentioned gen. so I need to know the current values in all lines to check if it" s suitable for the conected cable and the effect of unbalance on the the gen., proposal ATS terminal : [ L3g-N, L2g-L3,L1g-L2 ]."
Have I got this right. You are going to have 120 lts connected L-N from the main supply 220 v and you want to connect them L-L 220 V on the generator during outages. Correct?
12/15/2011 4:52 PM
yes correct
KH (3); PWSlack (2); SolarEagle (1); TonyS (1); wareagle (3)
