Previous in Forum: Home Made PWC "Human Dolphin" Flyboard Construction   Next in Forum: Steam Turbine
Valves Selection
12/15/2011 4:24 AM
Dear all
Kindly I have to select a valves will erected in vacuum possibility areas .is it will be the same specs for valve in normal place (no vacuum possibly)?
Please advise
Pathfinder Tags: valves
Re: Valves selection
12/15/2011 5:45 AM
Due allowance needs to be made for the pressure difference between that at sea level and that at absolute vacuum in the rating of the valves. For example, if the line is pressurised at 10barg max, and the surround is 0bara, then the pressure difference that the system "sees" is 11bar or thereabouts.
If the valves are located in a vacuum, then how do they get operated? Why is there a need to put the valves in a vacuum at all? How does anyone gain access to maintain the valve?
Re: Valves Selection
12/15/2011 8:14 AM
Good Answers: 67
12/27/2011 3:29 AM
How much vacuum? Vacuum service valves are specialised ones but if your vacuum is just a few torrs below the ambient you can use normal specs for valve.
Register to Reply 3 comments
lyn (1); pritam (1); PWSlack (1)
