Previous in Forum: Valves Selection   Next in Forum: M & Y Value of EPDM Food Grade Gasket.
Steam Turbine
12/15/2011 9:02 AM
Amount of cooling water required to condense 1ton of steam in condenser
Good Answers: 58
Re: Steam turbine
12/15/2011 9:06 AM
HOMEWORK ALERT!
This calculation should be in your text book......open it, read and learn!
CR4 is not a homework cheat site.
Good Answers: 101
Re: Steam Turbine
12/15/2011 11:42 AM
1 gigaton at -273.15oC at a flow rate of 1 megaton per second.
Re: Steam Turbine
12/15/2011 12:52 PM
banu....
Basic Thermodynamics:
Review the concepts of enthalpy and superheated steam on the internet. Come back with a real question later.
Re: Steam Turbine
12/16/2011 5:27 AM
What's the pass mark?
Register to Reply 4 comments
Anonymous Poster (1); DVader1000 (1); KJK/USA (1); PWSlack (1)
