Previous in Forum: Transformer Oil Conservator   Next in Forum: Cable Size When Increasing DC Voltage
TN-S
12/18/2011 6:41 AM
Dear Gurus,
For TN-S system, I know for TN-S system it is 3phase, 5W scheme, the system grounded neutral (N) and the equipment grounding protective conductor (PE) are separate, the system has redundant sources. It is possible to use only 3P breaker at the incomer and bus coupler since we will not use the neutral as current carrying conductor?
Re: TN-S
12/18/2011 8:30 AM
Why don't you just fax us the test and be done with it?
Re: TN-S
12/18/2011 12:54 PM
Dear Solar Eagle
What do you mean just fax it and be done with it.
Good Answers: 181
Re: TN-S
12/18/2011 8:55 PM
Basically you're being told to do your own homework.
Three questions in succession, all pointing towards a test paper you have been set. If you do the test on your own you will learn so much more. When you come to your final exams will you be able to ask an internet forum the answers, no you won't! Learn to think for yourself.
Good Answers: 117
Re: TN-S
12/19/2011 3:42 AM
if you send your test paper to us we will do it for you and get you your pass mark!
Good Answers: 117
Re: TN-S
12/19/2011 12:33 AM
WARNING: CR4 does not do homework!
Just how many times do we have to tell folk?
Re: TN-S
12/19/2011 3:38 AM
What's the pass mark?
Good Answers: 170
Re: TN-S
12/29/2011 6:46 AM
Yes! you can! provided, you are not connecting any standby source also to the same bus (in which case, at least one of the breakers, either of the incomers or the bus coupler, MUST be four pole). And, it is wromg to say that the neutral would not carry any current. Whether thro a breaker or not neutral conductor would surely carry the unblance currents.
Register to Reply 7 comments
brich (2); electricalexpert65 (1); jhunair (1); PWSlack (1); SolarEagle (1); TonyS (1)
