Previous in Forum: Tile Lining of Over Head Tank   Next in Forum: Butt Weld Fitting Used With Socket Weld Flanges
9 comments
Tile Adhesive
12/19/2011 1:47 AM
Some one will kind enough to tell me formula for making Tile Adhesive for Ceramic,
Vitrified & porcelin tile for the purpose of Tile on Tile fixing as well as Marble & Granite
on smooth surface. I am making the product but it is not up to mark with Standard
brands in Indian Market.
rajiv
Pathfinder Tags: adhesive
Good Answers: 141
Re: Tile Adhesive
12/19/2011 2:07 AM
Need more specs, as to adhesive force standards, drying time and application form and methods. What is your formula now?
Plenty of room here
Re: Tile Adhesive
12/20/2011 9:14 AM
AS per IS15477-2004,DRYING TIME 4 TO 8 HRS.APPLICATION - ON MOSAIC FLOOR,
LAYING OF NEW CERAMIC OR VITRIFIED TILE, SAY TILE ON TILE. WILL INFORM
YOU AFTER CONSULTING WITH OUR CHEMIST. IF YOU COULD PROVIDE ME GYPSUM
OR ROSIN BASE FORMULA, I SHALL BE HIGHLY OBLIGED.
RAJIV
Re: Tile Adhesive
12/19/2011 4:53 AM
Publish the formula here for the stuff being made now. The forum might be able to explain its shortcomings and suggest some improvements.
Re: Tile Adhesive
12/20/2011 9:29 AM
Pl. note formula-Cement-400kg,Coarse sand-160kg. Fine Sand-880kg..Dolomite-160kg.
Sodium Meta Silicate-20kg. Bentonite-24kg. POP-20kg. PVA G-17 GHOSENOL-8 kg.
All are mixed in Ball mill for about 40/60 minutes.
We get 82x20 kg bags in single batch.
Please suggest improvement and could we eliminate PVA (Being too costly-Rs.238/=per kg) and use Gypsum/Rosin or Resin.
rajiv
Good Answers: 102
Re: Tile Adhesive
12/20/2011 9:46 AM
How is your product not up to mark? Does it have a quantifiable deficiency or is it an intangible deficiency?
Re: Tile Adhesive
12/20/2011 9:57 AM
Product is quite good but we feel their is some thing missing comparing to standard brands,their tagging is better that`s why we feel both defeciencis are to be tackled.
Good Answers: 102
Re: Tile Adhesive
12/20/2011 10:27 AM
Define the deficiencies first. Then you'll know what you are tackling. Can't do much with just a feeling...
What do you mean by "tagging"
Re: Tile Adhesive
12/20/2011 10:37 AM
Tagging wrongly mention sorry for mistake its Here Tag means binding or Adhesion to
Surface on which Tile Adhesive is placed.
Good Answers: 141
Re: Tile Adhesive
12/20/2011 11:45 AM
If you mean tacking by application - while the "mud" is still wet - it can also be the course of your ingredients. This is a surface matter: too much granules (sand) = less contact.
Plenty of room here
Register to Reply 9 comments
dvmdsc (2); PWSlack (1); RAJIV AGARWAL (4); Wal (2)
