Previous in Forum: Earth Pressure   Next in Forum: What is Cyclic Service in Pressure Vessel?
GE DC 300 Variable Speed Motor Drive
12/22/2011 6:48 PM
We have an American lathe with a regenerative GE DC 300 spindle drive on it. The lathe has a two range head stock gearbox. There are only two parameters that I'm aware of for setting the accelerating (057) & decelerating (058) times. In low range forward the drive will get the motor up to speed & back to zero in the time selected in these parameters. Low range reverse starts & stops the motor in approximately two thirds of the time selected. High range forward accelerates & decelerates in approximately one half of the time selected. High range reverse performs in approximately one eighth to one tenth the time selected.
Does anyone know if there are other parameters for selecting the acceleration & deceleration time??
Jerry
Pathfinder Tags: machine tool control
Re: GE DC 300 VARIABLE SPEED MOTOR DRIVE
12/22/2011 6:55 PM
Don't know if this will help, but it might give you a clue where to start...
http://www.practicalmachinist.com/vb/monarch-lathes/ge-dc-drive-99896/
Re: GE DC 300 Variable Speed Motor Drive
12/27/2011 5:57 AM
The parameters you are setting are the times for the drive to get to base speed of the motor (acceleration) or from base speed back to zero (deceleration). So what might be happening is that only in forward-low range does the motor actually run at its base speed. In reverse the motor runs slower as well as in high range. Presumable there is a gear box so even though the spindle may be turning faster during high range operation the motor can be turning slower due to the gearing. So then the motor gets to target speed in less time then the accel times because its not accelerating to full speed.
Shawn
12/28/2011 11:43 AM
Thank you for the reply Shawn.
Yes there is a gear box, the lathe's head stock with the part chuck mounted on it. The top speed for the chuck in low range is 70 rpm & top speed for the chuck in high range is over 200 rpm. The motor's base speed is 850 rpm & the extended speed is 2600 rpm. Usually parts are cut on the operator's side in forward & < 50% of the time they cut on the back side in reverse, but they do run the part being cut in both forward & reverse & there definitly is a difference in accel & decel time in forward & reverse. The spindle is started & stopped frequently for tool insert changes. I wasn't aware the accel & decel time was for the base speed only. I'll need to get over there & look at the time from zero to base speed in both ranges.
Are you very familiar with the DC 300 drives?? If you are there other parameters for accelerating to & decelerating from extended speed??
Thanks again for the information, Jerry.
Jerry
12/29/2011 6:58 AM
Hi Jerry,
I am not familiar with the DC 300 drives, just drives in general, mostly VFD but also some DC drives. I would guess the relationship is linear but just a guess. Good Luck!
Shawn
Register to Reply 4 comments
badhabitrabbit (1); Shawn33 (2); SolarEagle (1)
