Previous in Forum: GE DC 300 Variable Speed Motor Drive   Next in Forum: Solar Cell ( Photovoltaic Cell)
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
What is Cyclic Service in Pressure Vessel?
12/23/2011 3:25 AM
Dear all,
1. What is the definition of cyclic service in pressure vessel?
2. How do i determine the number of cyclic service?
3. How to know the number of cyclic service during start-up, testing, and operation of pressure vessel?
Lets take example for this case is new LPG spherical tank.
Thank you.
Please give respectful & positive answer than insulting! Respect each other ok..
Pathfinder Tags: cyclic service spherical tank
Re: What is Cyclic Service in Pressure Vessel?
12/23/2011 3:33 AM
This would be a pressure vessel that cycles frequently from higher pressure to lower pressure. Local/regional Codes may have some definitions about how much the pressure difference is, and how often these cycles could occur. In extreme cases, metal fatigue could become a factor.
Good Answers: 70
12/23/2011 4:02 AM
Have you tried doing any research on your own, like starting here? You need to understand your first question so you can figure out your second and third questions. These all sounds like Home Work ??, or your trying to design a tank that is beyond your abilities. Designing any pressurized tank should done by a Certified Engineer, particularly one's holding flammable gases.
Good Answers: 137
12/23/2011 8:29 AM
Tornado has defined cyclic service for you. The other questions can only be answered by someone familar with the intended use of the vessel. There are standards relating allowable stress to number of cycles in design life.
12/24/2011 8:41 AM
←Look in here for your answers.
Register to Reply 4 comments
Codemaster (1); dj95401 (1); lyn (1); Tornado (1)
