Previous in Forum: Where do I Find Paddle Designs for Pin Homogenizers?   Next in Forum: GE DC 300 Variable Speed Motor Drive
Earth Pressure
12/22/2011 2:55 PM
Yes I have a question about pressure in the earth at depth's of a mile and a half where I calculate the it is 6355.94PSI approximately. According to laws on turbulence in dissipation to sustain turbulent flow, a constant source of energy supply is required. Otherwise turbulence dissipates rapidly as the kinetic energy by viscous shear stress. Turbulence causes the formation of eddies of many different length scales. This process continues, creating smaller and smaller structures which produces a hierarchy of eddies. Eventually this process creates structures that are small enough that molecular diffision becomes important and viscous dissipation of energy finally takes place. The scale at which this happens is the kolmogorov scale. So since the source of energy at a mile and a half is constant from the pressure in the surrounding granite, if you could transport a molten metal to that depth and pour it in a granite cut mold, would that constant pressure cause the metal to compress and become harder because of the constant pressure energy.
Re: Earth Pressure
12/22/2011 3:29 PM
I have only one thing to say...seek help
Re: Earth Pressure
12/22/2011 3:37 PM
<...6355.94PSI approximately...>
That figure is just not approximate enough. After all, the <...mile...> is only 1 significant digit.
<...turbulent flow...>
So this is in seawater, not rock? That distinction would vary the approximation above by a factor of 5. Fortunately for every living thing on land, rock is very viscous at everyday temperatures.
<...mile and a half...>
So, what's the pressure at that depth, approximately?
<...constant pressure energy...>
WTF is that? It didn't appear at all in A-level Physics!
-o-o-o-
Try switching to decaf.
Re: Earth Pressure
12/22/2011 3:54 PM
The bertha rogers drill hole in oklahoma, at 5.9 to 6. miles depth, according to wikipedia was almost 25000PSI, so 6355.94PSI is relitively accurate.
Re: Earth Pressure
12/22/2011 3:57 PM
I would say that in solid granite the turbulence would be strictly on the magnecular structure of the grain boundaries and would likely not be on the kolmogorov scale, but rather a smaller amount of turbulocity, more on the macular flux level.
The effect this would have on the grain structure of the metal in question, unless the metal is pure Cargonite, would be minuscule and not magnescule as one might expect.
Once the metal has begun to solidify and the grain structure becomes more or less morphologically entwined within its own boundary layers, the pressure exerted on it by the overlying structure will become negated by the interstitial space between each magnecule, thus leaving one with a metallic chunk of crap.
I hope this helps. If not, call me at BR-549, and we can discuss in excruciating detail.
Good Answers: 101
Re: Earth Pressure
12/22/2011 4:08 PM
Well... 6500PSI isn't all that hard to achieve up here on the surface of the earth. My Hydraulic test bench can do it no problem. So why not take your metal you want to test, place it into a pressure vessel, and run it up to 6355.94PSI and see what happens?
Re: Earth Pressure
12/22/2011 5:28 PM
That sounds a heck of a lot easier than carving out a granite mold a mile and a half down and filling it with molten metal.
Good Answers: 18
Re: Earth Pressure
12/23/2011 7:45 AM
Surely the "pressure" is the same as at the surface otherwise miners would need special suits to work.
Now the "weight" of the rock at that depth is a different thing.
Or have I got things completely wrong
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Register to Reply 7 comments
jesw55 (1); kramarat (1); lyn (1); PWSlack (1); RVZ717 (1); SolarEagle (1); Timothy Rissell (1)
