Previous in Forum: Frequency Change From 50 to 60 hz   Next in Forum: Pinout for Molex Connector on Uponor System
How to Choose Transformer
12/23/2011 4:57 AM
which step up transformer should i choose ? Ynd11 or Ynd1
I have to export power from 12mw generator to 22 kv line..which vector of transformer can be used .please list the factor affecting the selection of transformer..
Re: how to choose transformer
12/23/2011 5:08 AM
Does the 22kV line need a neutral?
Good Answers: 170
12/23/2011 6:40 AM
Assuming a star connected earthed generator, i would suggest yd1.
Good Answers: 181
12/23/2011 6:59 AM
Sounds like homework to me. I really can't imagine a qualified engineer on such a project having to ask the question.
Re: How to Choose Transformer
12/23/2011 6:47 PM
EE65
Why would you choose that one.
Good Answers: 170
12/29/2011 6:09 AM
Because, the power is exported to the grid. The end-user connected to the grid will normally have a Dyn11 transformer for his loads. Thus, he creates a + 30 degrees phase shift. If I have a Yd1 at the generating plant, I would have alreday created a - 30 degrees phase shift; so, the customer by having a Dyn 11 transformer at his location would shift thsi by plus 30 degrees, so that his voltage is in phase with the generated voltage.
12/26/2011 2:59 PM
depends what d utility wants?
utility = to which u r exporting power to
12/31/2011 1:27 PM
EE65
Great answer. Thanks
electricalexpert65 (2); muditmah (1); PWSlack (1); TonyS (1); wareagle (2)
