Previous in Forum: Providing for Motor Short Circuit Forces in Its Foundation Design   Next in Forum: Can We Rotate Tangential Bar Rotor Motor in Both the Direction
51 comments
Unknown Devices
12/27/2011 7:45 AM
Dear my friends.
I have some drawing for medium voltage compensating capacitor cabinet. But in this drawing, I don't know exactly one device ( I circled it in red shape in the first imagine, in the second focus in the device).
Anybody know it, please help me.
Thank you
Re: Unknown Devices
12/27/2011 10:59 AM
I don't know this simbol as it is as well, but by the look apears to be a full wave rectifier
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Re: Unknown Devices
12/27/2011 11:32 PM
u say ur user name electronic but u looks like dumptronics lol
Location: I am that kind of guy that no one seam to know were he is... sometimes not even I know were am I :!
Re: Unknown Devices
12/28/2011 6:26 AM
you see, as all can read by the diagram an opto isolator conected to a fuse and a large capacitor, and a few + and - simbols have all the logic! you are right and electronick is wrong! long live dumptronicks
Re: Unknown Devices
12/28/2011 11:37 AM
I'm not sure if you understand the spirit of this forum. The man gave his opinion of what he thought it might be. You chose to go in the gutter with your juvenile name calling. I didn't know what it was. redfred and JRaef also gave their opinions. I can guarantee you both of those guys are highly knowledgeable and I respect them both. You might want to step back and think about the value of sharing information. I like to think I'm pretty smart but I'd be a fool to think I knew it all. If you want to hang around here I suggest you listen more and make less of a jackass out of yourself.
Good Answers: 80
Re: Unknown Devices
12/28/2011 12:12 PM
GA! It is nice to have an adult in the room...
Re: Unknown Devices
12/29/2011 10:34 AM
the idea was not to offend any one! not even to assume to know everything, when I know that is not the case! If I did my apologies! but to defend the other opinion wich it appears valid as well... to be honest I think the designer of the circuit wanted to simbolise a rectifier electronicaly driven, and it may so hapen the gate triger to turn on that device may be a optocopler ok ? or it can be other. take it easy once there is a lot of crisis out there and you not need to make a storm in a glass of water! all the best!
Re: Unknown Devices
12/30/2011 6:31 AM
ok boy!!! tanks for the help pouch! calm down now.
Re: Unknown Devices
12/30/2011 12:46 PM
the freaking dog made the answer I guess !!! tanks! have a nice year!!
Re: Unknown Devices
01/05/2012 11:03 AM
yo, freaking einstein, so you know already the price of a report?
Re: Unknown Devices
01/09/2012 6:21 AM
you mean when the work is all done, but when jumping trains you loose all that was wrote?; do you mean when you leave the tent to check the surrounding and all of the sudden began to rain cats and dogs?; or, perhaps you are referring to the alien radio signals that just keep on following you and interfering with everything around!; nop, it is those kind of situations when you have to alert Houston... the price I cannot compute. let others decide mate
Re: Unknown Devices
01/10/2012 11:55 AM
hard misson joe?
Re: Unknown Devices
01/11/2012 5:31 AM
something like that bogzie! take it easy now puch!
Re: Unknown Devices
01/12/2012 6:23 AM
by the Bog, what do you plan to do now?
Re: Unknown Devices
01/13/2012 12:15 PM
the other mates told me to make a MBA... I just need to have a long vacation (though) far from my chain!
Re: Unknown Devices
12/27/2011 11:11 AM
The above is a full wave rectifier. Each triangle is a diode. I've never seen the symbol you have.
Re: Unknown Devices
12/27/2011 12:55 PM
I'm also not familiar with that symbol for a four lead device. The symbol inside the four lead device looks to me like a way to draw a Silicon Controlled Rectifier, a three lead device. However, the gate lead is not connected to anything. It might help to know what the connections are on the left for that ten node terminal block.
Good Answers: 804
Re: Unknown Devices
12/27/2011 1:32 PM
It looks like a "Damping Resistor Circuit" for reducing the spike that will occur when the capacitor contactors change state. In small LV systems the resistor is in the circuit momentarily ahead of closing the main contacts by being connected with electro-mechanical early-make aux. contacts driven by the contactor. In some MV systems they are switched in with SCRs. The SCR gate circuit is not shown in the power diagram because it is not a power circuit, just as the contactor coils are not shown in that diagram. But it is typically inconsequential anyway, it is often embedded with the resistor unit and not a user serviceable circuit.
Re: Unknown Devices
12/27/2011 11:04 PM
IT CALLED OPTO ISOLATOR
IT ONLY TRANSMIT ONLY SIGNAL NOT VOLTAGE OR AMPLITUDE
Good Answers: 80
Re: Unknown Devices
12/28/2011 10:07 AM
You should refrain from commenting on others' work when you don't understand it. Your two posts are totally wrong.
Re: Unknown Devices
12/31/2011 3:45 AM
Not only wrong, but VERY rude!!!!!!
Re: Unknown Devices
12/29/2011 3:40 PM
Do turn off Caps Lock before posting. Many readers consider the use of ALL CAPS to be akin to SHOUTING, and rather rude.
Good Answers: 69
Re: Unknown Devices
01/03/2012 1:09 PM
I have seen a whole lot of different types of optos, and they feature one L.E.D. (or two in parallel with oposite polarities, for bipolar or AC circuits). But I don't see in this symbol the streaking arrow that represents LIGHT comming out of the diode, much less the receiving device (i.e. phototransistor, either based or base-less, photo triac or photo SCR, Etc.
But despite this, you don't expect the power factor correcting currents to flow thru one opto coupler DO YOU ?.
I'd like to see the prodigy that you suggest in your desperate post: a signal with no voltage and no amplitude (wow).
Good Answers: 213
Re: Unknown Devices
12/27/2011 11:27 PM
I agree that it looks more like an optical isolator...
Re: Unknown Devices
12/28/2011 1:47 AM
I think they are the solid state relays for switching of the capacitor banks as per the requrements.
Good Answers: 102
Re: Unknown Devices
12/28/2011 3:24 AM
It is a solid state switch of sorts according to the diagram. Probably a Triac coupler.
Good Answers: 80
Re: Unknown Devices
12/28/2011 10:04 AM
Getting closer...
Good Answers: 19
Re: Unknown Devices
12/29/2011 2:27 PM
Very GA
Good Answers: 153
Re: Unknown Devices
12/28/2011 4:59 AM
I agree with shindvs that it is an opto isolator. If you look at the way it is wired, there is a single common on terminal 4 and three return wires on terminals 1-3. A pair of opto's are monitoring that each circuit is powered. This duplication suggests that sensing that the panel is correctly functioning is critical to the operation of the plant.
Good Answers: 82
Re: Unknown Devices
12/28/2011 7:05 AM
Or, perhaps it could be a current sensor?
Thanks, Win
Re: Unknown Devices
12/28/2011 7:34 AM
Please post a good picture.
Any how it seems to be CT or opto-coupler/isolator [in all phases] to monitor Capacitor-bank current.
Outputs from all CTs connected to control TB
Re: Unknown Devices
12/28/2011 10:20 AM
I thought the OP's pictures were better than many we see here!
I do NOT agree with the monitoring idea. Terminal 1 (bottom) is common for terminals 2,3, and 4. Each of those terminals 2,3, and 4 sends a control signal to turn on its pair of (Opto-Isolators / Solid State Relays) to connect the corresponding capacitor bank to the three phases of the line.
Note that drawing appears to have an error, where the leftmost capacitor bank connects to only two of the three phases!
Re: Unknown Devices
12/28/2011 10:30 AM
I don't think that there's an error there. The capacitors are connected in a three wire configuration not a four wire configuration. So current will not flow through the third leg unless at least one of the other two paths is turned ON.
Re: Unknown Devices
12/28/2011 4:29 PM
"So current will not flow through the third leg unless at least one of the other two paths is turned ON."That is true, and is why only two switching devices are required for each bank of capacitors.
The point I am referring to is:
On the left side of this part of the drawing, the left bank has two of the capacitors connected to the same phase, while the other two have one capacitor connected to each phase.
There is lettering on the drawing, but I can't quite read most of it.
Re: Unknown Devices
12/28/2011 5:36 PM
You're correct, I was looking at the wrong part of the circuit. There appears to be an error there.
Good Answers: 80
Re: Unknown Devices
12/28/2011 9:29 PM
GA! good catch!
Good Answers: 19
Re: Unknown Devices
12/29/2011 2:30 PM
Leave it to a "Hang Town" man. Just down the road in CP.
GA
Re: Unknown Devices
12/29/2011 3:49 PM
Cameron Park, I presume... Thanks for the GA in words if not in actions...
Yep! I've been in P'ville since'69, although I currently spend almost half of my time in San Diego.
Season's greetings.
Dick
5
Good Answers: 80
Re: Unknown Devices
12/28/2011 10:18 AM
It is a fast semiconductor switch for capacitor banks.
We use those to switch in and out capacitor banks rapidely and with minimal inrush by timing the commutation at the voltage zero crossing.
Unlike electro-mecanical contactors, the thyristors can be switched on at the exact moment the line voltage accross it is zero preventing the large current spike common to contactors. Since there isn't any inrush, it can be operated millions of times without contact ware or capacitor damages.
When you combine these switches with a fast controller, you can adjust the power factor correction every half cycle (times 3 on 3 phases). This allow you to compensate a starting motor's reactive power as it accelerates.
This technology can greatly enhances the plant voltage regulation when it is affected by rapidely changing reactive loads.
I designed such a system a few years ago for difficult applications (oil rigs).
Happy new year everyone!
P.S. In a delta arrangement of the capacitor bank, only two lines need to be controlled as the current has nowhere to go when the two switches are off. The bank then floats at the uncontrolled line voltage. Just don't touch it...
Re: Unknown Devices
12/28/2011 10:25 AM
Thanks for the explanation of the part short hand symbol identification and the whole circuit functionality.
Re: Unknown Devices
12/28/2011 10:36 AM
why it in one box it is opto isolator mean inside one LED & another side photo sensitive diode or photo diode
Good Answers: 80
Re: Unknown Devices
12/28/2011 10:58 AM
This is the way the system designer has represented this double thyristor switch. You originally associate it to an opto-coupler and don't seem to want to accept your mis-interpretation.
It is simply two thyristors with a box in between. This most likely represent the gate driver or maybe a snubber. The details of the drawing are not important, it is the overall functionality that counts.
You seem new at electronics. You will see many different ways of representing components over the years. Sometimes, you need to know about the circuit functionality to identify a strange symbol. Once you figure it out, you realize that the symbol wasn't that bad after all...
Keep your mind open and look at things with different perspectives when you are stuck in a dead end.
I hope you have as much fun discovering electronics as I have.
Regards,
Marco
Good Answers: 102
Re: Unknown Devices
12/28/2011 9:21 PM
If you have a look at the link I provided in #9 (Triac Coupler) you will see that it may satisfy your intuitive belief.
A triac (opto) coupler provides isolated switching.
The position of these devices in the circuit screams control not monitoring.
Re: Unknown Devices
12/28/2011 11:08 AM
I presume something similiar to solid state relays which can be controlled with various inputs.
Good Answers: 69
Re: Unknown Devices
01/03/2012 1:36 PM
GA Sir ! nothing but an SSR makes sense here.
Good Answers: 19
Re: Unknown Devices
12/28/2011 7:50 PM
Taking your picture and blowing it up in Adobe it appears to be a A/C - D/c rectifier. Neutral and 240 in. Or an early version of an SCR.
Good Answers: 102
Re: Unknown Devices
12/28/2011 9:27 PM
The fact that we are all having to guess what the devices are is a little disturbing.
What ever happened to using standardised symbols or functional blocks with annotations as required for oddities?
The original author of the diagram may have struggled to find a "standard" so she made up her own without an explanation and expected the reader to somehow just know what she was thinking.....
Good Answers: 80
Re: Unknown Devices
12/28/2011 9:40 PM
This is a complex assembly that doesn't have any standardized symbol that I know of.
I actually find it easy to interpret as it is in my field of work. It could certainly be difficult to recognize for a person used to low power electronics.
There is the issue of the error in the power distribution above the fuses. I find it strange that it made it that far without being corrected. Maybe the OP can give us more history behind this schematic.
Wal, why do you imply that the designer was female?
Re: Unknown Devices
12/28/2011 11:13 PM
I agree with your question towards Wal, but then I immediately questioned why it bothered me about the gender they choose. There is a singular gender neutral pronoun in English, they & their. Unfortunately it is also a collective noun, so it is not as often used by those who have a gender neutral pronoun in their native tongue or who don't have as many ambiguous words as English has.
Let's cut Wal some slack to explain, ignore, or hang themselves.
Good Answers: 102
Re: Unknown Devices
12/29/2011 12:07 AM
If I used male personal pronouns then nobody would give a rat's.
I'm all for gender equality. Males aren't always to blame.....
Re: Unknown Devices
01/03/2012 1:00 PM
Getting back to your point here without the distraction of gender choice, its not so disturbing to me that we have to guess what a non-standard symbol means. What disturbs me is that the OP asks us instead of asking the originator of this document. I do believe marcot has accurately identified the mystery block generic function. However, unless one can refer back to real manufacturer part numbers and data sheets or even standard symbols the nominal and limitation parameters of this mystery block are still unknown.
Re: Unknown Devices
01/03/2012 12:42 PM
Dis louks like some suort of double Schmitt trigger... Sie müssen den Abzug schießen, um den Motor auf Wiedersehen anzufangen!
Register to Reply 51 comments
bone_z (5); cwarner7_11 (1); dkwarner (3); electronick (6); Fredski (2); garth (1); Haajee (1); jhhassociates (1); JRaef (1); lyn (1); marcot (7); Priyadarshan (1); PWSlack (1); redfred (6); shindvs (3); SolarEagle (1); Stedou73ish (3); Wal (4); Winfield Hill (1); Yahlasit (2)
